Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-23-2014, 14:20   #1 (permalink)
Member: 1014618
Sonork: 100.1637137
Thanks Meter: 110
lumia 920 dead boot repaired success but NOT POWER
I successfully did lumia 920 dat was dead but after jtag repair d fone still off (no power, no light, no viberate)
Old 09-23-2014, 14:25   #2 (permalink)
Member: 1014618
Sonork: 100.1637137
Thanks Meter: 110
pls wat else can i do to d fone?
customer said dat fone just went of after low battery but now battery is over 50% not still power d fone is just 4month old
Old 09-23-2014, 14:26   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@TBOUY
First Check your Battery Voltage with Multitester...
If should be atleast 4.0v... A fully charged phone should give you 4.10V.
If your battery is less than this, then it means it is discharged... That is why it will not power ON.
Solution is to charge battery EXTERNALLY using another phone or an external Charger.
You can also charge it via USB Cable + and -.... But this is dangerous if you lack experience.
If your Battery is above 4.0v then Use FFU Flasher via JTAG.
Match Product Code of Phone to Flash File you will use for FFU Flashing.
More Info Here:
http://forum.gsmhosting.com/vbb/f609...edure-1854823/
Old 09-23-2014, 16:00   #4 (permalink)
Member: 1014618
Sonork: 100.1637137
Thanks Meter: 110
all i can see there is bigboot just like d 1 i downloaded previously
I CANT FIND D FFU APF FILE
Old 09-23-2014, 16:10   #5 (permalink)
Member: 651945
Check here:
http://forum.gsmhosting.com/vbb/f609...hread-1855079/
Download and install that version
Old 09-23-2014, 16:14   #6 (permalink)
Member: 1014618
Sonork: 100.1637137
Thanks Meter: 110
i ve got it its in my atf nokia folder
i will re do d jtag soldering
Page generated in 0.15602 seconds with 8 queries
