12-06-2013, 15:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | Lumia 920 flash problem - (SOLUTION INSIDE) log: ================================================== ==== 20:12:31 : Flash File Checksum Verification 20:12:31 : ================================================== ==== 20:12:45 : RM821_3049.0000.1330.0006_RETAIL_apac_australia_ne w_zealand_304_06_259494_prd_signed.ffu: CHECKSUM PASSED 20:12:45 : ================================================== ==== 20:12:45 : Verification Done... 20:12:47 : Windows Phone 8 Flashing Started 20:12:47 : Loading Flash Files Please Wait... 20:12:47 : 20:12:47 : ================================================== ==== 20:12:47 : Windows Phone 8 Lumia Flasher 20:12:47 : ================================================== ==== 20:12:47 : 20:12:47 : If the Phone is ALIVE 20:12:47 : 1. Power On the Phone and Connect it to the USB Port 20:12:47 : 20:12:47 : If the Phone is DEAD 20:12:47 : 1. Connect Phone to the USB Port 20:12:47 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 20:12:47 : 3. Wait until the Phone Vibrates Shortly... 20:12:47 : 4. Stop Pressing the Buttons... 20:12:47 : ================================================== ==== 20:12:47 : 20:13:02 : IMEI: 3541490544xxxxx 20:13:02 : Version: 1.1.1.3 20:13:02 : Product Code: 059R0H3 20:13:02 : Module Code: 0205137 20:13:02 : Basic Tranceiver Code: 059N5Q1 20:13:13 : 20:13:13 : Boot Flash Mode Successful... 20:13:13 : 20:13:13 : Phone Info Query Start... 20:13:13 : Blocks Returned: 0x02 Blocks 20:13:13 : Block ID 0x01 :00241000 20:13:13 : Block ID 0x04 :010E0119 20:13:13 : Checking SD Card Size... 20:13:13 : Card Size: 0x00040004 20:13:13 : Checking Platform Security Status... 20:13:13 : Platform Secure Boot Status: Not Active 20:13:13 : Secure FFU EFUSE Status: Not Active 20:13:13 : Debug Status: Not Active 20:13:13 : RDC Status: Active 20:13:13 : Authentication Status: Not Active 20:13:13 : UEFI Secure Boot Status: Active 20:13:13 : Checking Secure FFU Mode... 20:13:13 : Secure FFU Mode : NONE 20:13:13 : Query Flash App Information... 20:13:13 : Flash App Information: 00040004010E0119746E69206720206F 20:13:13 : Flash App Protocol Version: 4.0 20:13:13 : Flash App Implementation Version: 4.1 20:13:13 : Query ROOT KEY HASH... 20:13:13 : ROOT_KEY_HASH: 00040004010E0119746E69206720206F 20:13:13 : ERROR: Flash File ROOT_KEY_HASH Mismatch! 20:13:13 : This Flash File is NOT COMPATIBLE with this Phone. 20:13:13 : ERROR: Flashing Failed! 2nd try this product code : 059R2B8 log: 20:20:08 : ================================================== ==== 20:20:08 : Flash File Checksum Verification 20:20:08 : ================================================== ==== 20:20:24 : RM821_1232.5957.1308.0001_RETAIL_im_india_443_01_1 46688_prd_signed.ffu: CHECKSUM PASSED 20:20:24 : ================================================== ==== 20:20:24 : Verification Done... 20:22:33 : Windows Phone 8 Flashing Started 20:22:33 : Loading Flash Files Please Wait... 20:22:33 : 20:22:33 : ================================================== ==== 20:22:33 : Windows Phone 8 Lumia Flasher 20:22:33 : ================================================== ==== 20:22:33 : 20:22:33 : If the Phone is ALIVE 20:22:33 : 1. Power On the Phone and Connect it to the USB Port 20:22:33 : 20:22:33 : If the Phone is DEAD 20:22:33 : 1. Connect Phone to the USB Port 20:22:33 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 20:22:33 : 3. Wait until the Phone Vibrates Shortly... 20:22:33 : 4. Stop Pressing the Buttons... 20:22:33 : ================================================== ==== 20:22:33 : 20:22:50 : IMEI: 3541490544xxxxx 20:22:50 : Version: 1.1.1.3 20:22:50 : Product Code: 059R0H3 20:22:50 : Module Code: 0205137 20:22:50 : Basic Tranceiver Code: 059N5Q1 20:22:53 : 20:22:53 : Boot Flash Mode Successful... 20:22:53 : 20:22:53 : Phone Info Query Start... 20:22:53 : Blocks Returned: 0x07 Blocks 20:22:53 : Block ID 0x01 :00241000 20:22:53 : Block ID 0x02 :00240000 20:22:53 : Block ID 0x03 :03A3E000 20:22:53 : Block ID 0x05 :Nokia.MSM8960.P4301.3.2.1 20:22:53 : Block ID 0x0D :0001 20:22:53 : Block ID 0x0F :0301010100000101FF 20:22:53 : Block ID 0x10 :0100030000 20:22:53 : Checking SD Card Size... 20:22:53 : Card Size: 0x00000000 20:22:53 : Checking Platform Security Status... 20:22:53 : Platform Secure Boot Status: Active 20:22:53 : Secure FFU EFUSE Status: Active 20:22:53 : Debug Status: Active 20:22:53 : RDC Status: Not Active 20:22:53 : Authentication Status: Not Active 20:22:53 : UEFI Secure Boot Status: Active 20:22:53 : Checking Secure FFU Mode... 20:22:53 : Secure FFU Mode : SYNC + ASYNC 20:22:53 : Query Flash App Information... 20:22:53 : Flash App Information: 02010E011900 20:22:53 : UEFI App: FLASH APP 20:22:53 : Flash App Protocol Version: 1.14 20:22:53 : Flash App Implementation Version: 1.25 20:22:53 : Query ROOT KEY HASH... 20:22:53 : ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C4 9BC0DB952A6BB4 20:22:53 : 20:22:53 : Sending Image Signatures... 20:22:53 : Image Signatures Accepted! 20:22:53 : Erasing Data Partition... 20:22:57 : Data Partition Erased Successfully 20:22:57 : Preparing Buffers for DATA LOOP... 20:22:57 : Allocating System RAM OK! 20:22:57 : Start Sending DATA BLOCKS... 20:25:45 : ERROR: LAST DATA BLOCK REJECTED! 20:25:45 : Check your Flash File and Phone Connection 20:25:45 : ERROR: Flashing Failed! now phone flash and last moment show error now any file can not flash this phone all time show This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! solution need |
12-11-2013, 10:03 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @O2&Voda Last Block Rejected because phone does not accept your flash file. Why will it not accept it? Because there are 3 versions of Files: 1xxxx.xxxx.xxxx.xxxx 2xxxx.xxxx.xxxx.xxxx 3xxxx.xxxx.xxxx.xxxx You cannot flash "some" phones from 1xxxx.xxxx.xxxx.xxxx to 3xxxx.xxxx.xxxx.xxxx or from 3xxxx.xxxx.xxxx.xxxx to 1xxxx.xxxx.xxxx.xxxx. So if phone does not accept your 1xxxx.xxxx.xxxx.xxxx flash file, then flash it with 3xxxx.xxxx.xxxx.xxxx and you will fix "ERROR: LAST DATA BLOCK REJECTED!" and If phone does not accept your 3xxxx.xxxx.xxxx.xxxx flash file, then flash it with 1xxxx.xxxx.xxxx.xxxx and you will fix "ERROR: LAST DATA BLOCK REJECTED!" @brokendreem Flash your phone again with 3xxxx.xxxx.xxxx.xxxx flash file. It should work already as your FIRST logs show a temporary buffer read error on WinUSB only and not actually a Phone ERROR> B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
07-16-2014, 07:48 | #6 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Hello..Lumia 920 can't connect to any wifi..incorrect password...Is software or hardware ? Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Version: 1.1.1.3 Product Code: 059Q9H2 Module Code: 0205137 Basic Tranceiver Code: 059N5Q3 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 03A3E000 Block ID 0x05 : Nokia.MSM8960.P4301.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C4 9BC0DB952A6BB4 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:21 |
