04-01-2014, 21:23 | #1 (permalink) |
Registered User Join Date: Jan 2011 Location: rawalpindi
Member: 1494799 Status: Offline Sonork: 100.1602242 Thanks Meter: 15 | lumia 920 flashing error Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 03A3E000 Block ID 0x05 : Nokia.MSM8960.44߿A.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 020109011000 UEFI App: FLASH APP Flash App Protocol Version: 1.9 Flash App Implementation Version: 1.16 Query ROOT KEY HASH... ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C4 9BC0DB952A6BB4 Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! plz help me dear atf team |
The Following User Says Thank You to adnanrawalpindi For This Useful Post: |
04-02-2014, 06:37 | #4 (permalink) |
No Life Poster Join Date: Oct 2008 Location: chennai
Member: 880497 Status: Offline Thanks Meter: 197 | I think this is a software bug........have a look at here http://forum.gsmhosting.com/vbb/f609...ailed-1794096/ |
04-02-2014, 18:00 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @ALL Just flashed Nokia Lumia 920 RM-821 with ATF 11.10 without any problem: Code: 19:55:09 : ====================================================== 19:55:09 : Windows Phone 8 Lumia Flasher 19:55:09 : ====================================================== 19:55:09 : 19:55:09 : If the Phone is ALIVE 19:55:09 : 1. Power On the Phone and Connect it to the USB Port 19:55:09 : 19:55:09 : If the Phone is DEAD 19:55:09 : 1. Connect Phone to the USB Port 19:55:09 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 19:55:09 : 3. Wait until the Phone Vibrates Shortly... 19:55:09 : 4. Stop Pressing the Buttons... 19:55:09 : ====================================================== 19:55:09 : 19:55:39 : IMEI: 354149055652546 19:55:39 : Version: 1.1.1.2 19:55:39 : Product Code: 059R840 19:55:39 : Module Code: 0205137 19:55:39 : Basic Tranceiver Code: 059N5Q5 19:55:50 : 19:55:50 : Boot Flash Mode Successful... 19:55:50 : 19:55:50 : Phone Info Query Start... 19:55:50 : Blocks Returned: 0x07 Blocks 19:55:50 : Block ID 0x01 :00241000 19:55:50 : Block ID 0x02 :00240000 19:55:50 : Block ID 0x03 :03A3E000 19:55:50 : Block ID 0x05 :Nokia.MSM8960.P4301.3.2.1 19:55:50 : Block ID 0x0D :0001 19:55:50 : Block ID 0x0F :0301010100000101FF 19:55:50 : Block ID 0x10 :0100030000 19:55:50 : Checking SD Card Size... 19:55:51 : Card Size: 0x00000000 19:55:51 : Checking Platform Security Status... 19:55:51 : Platform Secure Boot Status: Active 19:55:51 : Secure FFU EFUSE Status: Active 19:55:51 : Debug Status: Active 19:55:51 : RDC Status: Not Active 19:55:51 : Authentication Status: Not Active 19:55:51 : UEFI Secure Boot Status: Active 19:55:51 : Checking Secure FFU Mode... 19:55:51 : Secure FFU Mode : SYNC + ASYNC 19:55:51 : Query Flash App Information... 19:55:51 : Flash App Information: 020109011000 19:55:51 : UEFI App: FLASH APP 19:55:51 : Flash App Protocol Version: 1.9 19:55:51 : Flash App Implementation Version: 1.16 19:55:51 : Query ROOT KEY HASH... 19:55:51 : ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C49BC0DB952A6BB4 19:55:51 : 19:55:51 : Sending Image Signatures... 19:55:51 : Image Signatures Accepted! 19:55:51 : Erasing Data Partition... 19:55:55 : Data Partition Erased Successfully 19:55:55 : Preparing Buffers for DATA LOOP... 19:55:55 : Allocating System RAM OK! 19:55:55 : Start Sending DATA BLOCKS... 19:58:43 : Finished Sending all DATA BLOCKS! 19:58:43 : Exiting FLASH Mode via REBOOT... 19:58:43 : Exit FLASH Mode Successful! 19:58:43 : 19:58:43 : Flashing Done! 19:58:43 : Total Flashing Time : 00:02:53 1. Make sure phone's battery is fully charged 2. Try flashing once again with different version: If you flashing with v3xxx.xxxx.xxxx.xxxx then flash with 1xxx.xxxx.xxxx and so on 3. Check your flash files, may be corrupted / incomplete download files Also post here complete logs as I posted my logs. BR |
04-03-2014, 16:26 | #6 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Quote:
I'm added some new info about my (i hope not only my) problem. I hope, it help you to solve our problems. 1. I can see, not only in my case, the next message FW Version Check=Active, in the low string of box window. If it necessary, i can place links and posts numbers. 2. I'm also see only one USB Composite Device in my Device Manager. It's not correspond to Advance Box's Device Manager. Maybe it my not activated JTAG? 3. And there are old info. Modular incompatibility solved today, but ATF Box can't flash anything, even good set. here the log: Number of Image Files: 3 Processing Image File : rm56b5003.81.mcusw.bin CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 720 Entry Point: 0x43D8 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm56b5003.81.ppm_k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 277 Entry Point: 0x0077 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm56b5003.81.image_k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 300 Entry Point: 0x007A Page Format : -1 MAX PAGE : 0x00004000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ERROR: BOOTROM NOT DETECTED AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ERROR: BOOTROM NOT DETECTED AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 3 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 11800217 ID DWORD 1 : 74796E56 ID DWORD 2 : 0A690DD5 ID DWORD 3 : B77E7ADE ID DWORD 4 : 8A78CC98 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F ADL_SERVER: PROCESSING rm56b5003.81.mcusw.bin ADL_SERVER: ROOT_KEY_HASH MATCH FOUND ADL_SERVER: PROCESSING rm56b5003.81.mcusw.bin ADL_SERVER: CMT CERTIFICATE BLOCK FOUND ADL_SERVER: CMT DATA BLOCKS FOUND ADL_SERVER: CONSOLIDATING CMT BLOCKS ADL_SERVER: PASUBTOC BLOCK FOUND BB5 ADL Loader Start Up... (Please Wait...) Found Nokia BB5 ADL Loader USB Generic... ================================================== ===== Processing : rm56b5003.81.mcusw.bin ================================================== ===== Erase Block Found >> Erasing area 0x00180000 - 0x00B69431, Type: NOR , Subsystem: CMT >> Erasing area 0x00000000 - 0x000FFFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00120000 - 0x0017FFFF, Type: NOR , Subsystem: CMT >> Erasing area 0x00C00000 - 0x0117FFFF, Type: NOR , Subsystem: CMT Erase Complete : No Error - 0 (0x00) Data Block Found : 720 Blocks ERROR: Data Block Not Accepted (0x0000) Flashing FAILED Booting/Flashing Failed... Please Try Again... BR. | |
04-12-2014, 21:25 | #8 (permalink) | ||
Crazy Poster Join Date: Jun 2006 Location: Russia Ershov Age: 40
Member: 296280 Status: Offline Thanks Meter: 34 | Quote:
for example : Quote:
The Following User Says Thank You to renat_d For This Useful Post: |
04-14-2014, 11:22 | #9 (permalink) | |
1. I can see, not only in my case, the next message FW Version Check=Active 2. I'm also see only one USB Composite Device in my Device Manager. 3. Now some new info - | |
