03-29-2014, 00:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | Lumia 920 not booting i have a very strange behaviour of a Lumia 920 here. I received it from ebay today, with broken LCD. It was switched on, as the digitizer didn't respond anymore. So i changed the display. After changing, the phone won't boot anymore. Stuck at Nokia Logo. I tried reflashing with Black firmware, and i got Error. I tried flashing with Black again (i think). Then it worked. But phone still won't boot. So i flashed with Amber Rom - still the same. Phone not booting. Then i restored boot with JTAG. Operation was successful. But phone still won't boot. But it's not stuck at NOkia logo, it keeps rebooting all the time. Like: Nokia Logo --> Display shortly off (reboot?) --> Nokia Logo --> and so on, and so on... after about 5 reboots, it displayed an orange T shortly, then rebooted again. So i tried to flash again with Black firmware. No success. I get flashing Error. So i flashed with Amber again. Now it's Stuck at Logo again. Can you please help me?!! Thanks. Last edited by lordmaxey; 03-29-2014 at 00:33. |
03-29-2014, 05:51 | #3 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: Kushtia,Bangladesh Age: 36
Member: 1217358 Status: Offline Sonork: 100.1605541 Thanks Meter: 156 | Quote:
03-29-2014, 07:57 | #4 (permalink) |
Member: 1078009 Status: Offline Thanks Meter: 12 | Sorry, i don't understand. Which new updated version? Sorry, i don't understand. To which flashfiles should i change? I downloaded the latest Firmware for the phone's Product Code via Navifirm, flashing went ok, but it still does not boot. |
03-30-2014, 12:44 | #5 (permalink) |
Member: 1078009 Status: Offline Thanks Meter: 12 | Ok, new day, new try. I flashed firmware with ATF successfully. Black fw for phones pruduct code. But still same error, phone is not booting up. I tried repair boot with ATF JTAG again, but it fails: This is the full log: Code: Default language ID 0x0407 JTAG Interface Connected, S/N 0xFC8A01CD Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 1, compiled 28.08.2013 19:16:00 ========================================================== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage TYpe: eMMC 32GB Boot Package: 1232.5962.1314.0009 (BIG BOOT) ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Loading AFP (Please Wait)...OK AFP revision 1, compiled 28.08.2013 19:16:00 ========================================================== Phone Type : Lumia 920 RM-821 CPU Type : Qualcomm MSM8960 Storage TYpe: eMMC 32GB Boot Package: 1232.5962.1314.0009 (BIG BOOT) ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x706B40E1 IR11 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Cannot Halt Core! Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Hynix HBG4e, 29.12 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring MBR Data...OK Restoring GPT Data form AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...Flash Write Error at 0x0A114000, DCC Write Error, USB I/O Error, Code 0x00000004 Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= JTAG Interface Disconnected! JTAG Interface Connected, S/N 0xFC8A01CD Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x706B40E1 IR11 Saving "..\Logs\Screenshots\2014-03-30_13-40-13.jpg"...OK Edit: Another strange thing: After using JTAG, i need to follow this solution to get box working again. http://forum.gsmhosting.com/vbb/f609...ution-1785903/ |
04-02-2014, 08:28 | #7 (permalink) |
Member: 1078009 Status: Offline Thanks Meter: 12 | OK I boot repaired the Lumia 920 successfully yesterday. Also the flashing went fine. But when i turn it on, it's still stuck @Nokia logo So i tried flashing with nokia care suite, i plugged the phone into usb port and had care suite running. I was searching for the right place where i should put the flashfiles... Then the phone magically booted up. Wow. But the changed screen was also not responding I rebooted the phone to check if booting works now - but it's stuck again. Is this a hardware fault? |
04-02-2014, 17:50 | #8 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
