07-11-2015, 03:54 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | LUMIA 930 show Qualcomm hs-usb qloader? i try to install emergency driver dont work what to do? |
07-11-2015, 11:35 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | You no need of The Nokia emergency connective drivers. SEE http://forum.gsmhosting.com/vbb/f609...hread-1962997/ |
07-13-2015, 02:55 | #5 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
or i still have open phone and solder wires? | |
07-13-2015, 15:55 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL Almost ALL Lumias 8.0 and 8.1 are Supported for Repair BOOT via USB cable only... But of course, if the problem is the eMMC CHIP, then it is not possible to repair the phone via USB Cable only... For Problems with installing "Nokia Emergency Drivers", download latest version here: http://174.120.45.27/tmp/EmergencyDo...Driver_new.rar This will solve issues with "Specified File Not Found" in previous driver package version. Once Emergency Driver is installed, ALL YOU HAVE TO DO IS FLASH THE PHONE VIA USB CABLE USING ATF SOFTWARE. There is no special settings to select... Just flash phone like NORMAL FLASHING. Show Flashing Logs if you encounter any errors... |
07-14-2015, 02:25 | #9 (permalink) | |
so can u plz tell me the driver u give us where it install so i can find right path and install emergency driver manually thanks | |
07-14-2015, 05:22 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Just uninstall qualcomm drivers via right click in device manager. When qualcomm drivers ar uninstalled, your pc will use nokia emergency drivers. Use google to learn more about driver installation. They will have pictures to explain more clearer. |
07-14-2015, 05:31 | #11 (permalink) | |
thanks | |
