Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| Lumia DEAD BOOT REPAIR and UNLOCK ... "Thread for success logs" Hi, let's post here all successfully DEAD BOOT repaired and unlocked lumia phones by ATF Box: Starting from X-Shadow's screen shots: Lumia 710 BOOT repair.. ATF XG223 9.15 Update - AUTO UPDATE!! Public Discussion Thread: Lumia 900 BOOT repair.. ATF XG223 9.15 Update - AUTO UPDATE!! Public Discussion Thread: Lumia 800 unlocking logs: Quote:
| The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post: |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: unitechmaghreb Age: 34
Member: 49263 Status: Offline Sonork: 100.92840 Thanks: 117
| ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 00626E41 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:02:16 Wow ATF Did it maybe direct unlock for SL3 in next update Congratulation to the team for the Hard Work like say Bph&co this Team Devlope and create not make copy paste. |
| The Following 4 Users Say Thank You to multimedia box For This Useful Post: |
| | #4 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks: 19
| @tontonflach Unlock should take less than 3 minutes for 710,, your logs show 29 minutes++ Did it really take that long? Try To Flash phone with Known AMSS file Flash AMSS file only, using the + MCU button in ATF and select either one of the files RM803_11w46_5_prod_generic_amss.esco RM803_11w50_2_prod_generic_amss.esco RM803_11w50_prod_generic_amss.esco RM803_12w05_prod_generic_amss.esco RM803_12w07_prod_generic_amss.esco RM803_12w11_1_prod_generic_amss.esco RM803_12w12_1_prod_generic_amss.esco RM803_12w12_2_prod_generic_amss.esco RM803_12w12_prod_generic_amss.esco RM803_12w18_prod_generic_amss.esco RM809_11w45_2_prod_generic_amss.esco Only Flash AMSS file, do not flash MCU PPM etc... After you flash it to the phone, check your PM. |
| The Following 5 Users Say Thank You to Advance-Box For This Useful Post: |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: ๑۩INDIA۩$
Member: 733702 Status: Offline Thanks: 340
| Nokia lumia 710 successfully boot repaired by atf FIRST USER IN THE WORLD WHO HAVE TESTED NOKIA LUMIA 710 SUCCESSFULLY BOOT REPAIRED BY ATF OSBL DLOAD (NOKIA) REPAIR OSBL QCOM (QUALCOM) REPAIR THANKS TO ADVANCE BOX TEAM YOU REVIVED MY PHONE |
| The Following 17 Users Say Thank You to laxman kumar For This Useful Post: |
| | #8 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2007
Member: 423802 Status: Offline Thanks: 33
| Lumia 800 unlock doneeeeeeeeeeeeeee 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 001CE144 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:20 |
| The Following 4 Users Say Thank You to rahul.grover For This Useful Post: |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: PAKISTAN
Member: 227428 Status: Offline Thanks: 161
| SUCCESSFULLY unlock Lumia 710 16:43:31 : ================================================== ==== 16:43:31 : Lumia Test Point Connection Module 16:43:31 : ================================================== ==== 16:43:31 : ================================================== ==== 16:43:31 : 16:43:31 : 1. DO NOT USE THE PHONE"S BATTERY 16:43:31 : 2. Connect the Soldered TP Connections to ATF Box 16:43:31 : 3. Disconnect the USB Cable and Wait until the 16:43:31 : the ATF Software will tell you to Connect the USB. 16:43:31 : 16:43:34 : 16:43:34 : Interface Reset OK! 16:43:34 : Reading Platform Information... 16:43:34 : Selecting Active Handle... 16:43:34 : Select Handle OK! 16:43:34 : Sending Ping... 16:43:34 : Ping Reply OK! 16:43:34 : 16:43:34 : Lumia 710 Detected 16:43:34 : 16:43:34 : Storage Device Information 16:43:34 : Manufacturer ID: 90 16:43:34 : Application ID : 014A 16:43:34 : Product Name : HYNIX 16:43:34 : Product Rev : 5D 16:43:34 : Product SN : 005FC7C6 16:43:34 : 16:43:34 : Protection Information 16:43:34 : Write Protect A: OFF 16:43:34 : Write Protect B: OFF 16:43:34 : 16:43:34 : 16:43:34 : Dumping AMSS FAT16 Region 16:43:34 : Please wait for 2-4 Mintues... 16:45:35 : Patch Bit Found... 16:45:35 : Total Patch Bits Found: 1 16:45:35 : Patching AMSS... 16:45:36 : Patch OK! 16:45:36 : 16:45:36 : SP Unlock Done! 16:45:36 : 16:45:36 : PIN: 00000000 16:45:36 : PUK: 0000000000 16:45:36 : 16:45:36 : Total Elapsed Time 00:02:58 Thx To Atf Team For This Gr8 Update Gr8 Team.......... |
| | #11 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Mar 2004 Location: LATVIA - SL3 CODES CALC Age: 34
Member: 56504 Status: Offline Thanks: 1
| my first lumia unlocked Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 088751AB Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:06 |
| | #12 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Lebanon
Member: 610529 Status: Offline Sonork: 100.1612153 Thanks: 72
| 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: Sending Boot Failed! Check your Test Point Soldering! BOOT Images Written Successfully! Total Elapsed Time 00:00:05 what is a problem i check all wires its ok |
| | #13 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Aug 2007
Member: 565230 Status: Offline Thanks: 79
| lumia 800 unlocked ok with tp hello, it's a very hot update it's done with ATF v9.10 Code: ======================================================
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 80
Application ID : 0000
Product Name :
Product Rev : 0C
Product SN : 02008820
Patch Bit Found...
Patch Bit Found...
Total Patch Bits Found: 2
Patching AMSS...
Patch OK!
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:31 ![]() B R |
| | #14 (permalink) |
| @amer_a_82 You are sure you connected yellow and red wire together? What Phone are you trying to TP? Are you using ATF BIG or ATF Nitro/Lightning ? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
