Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-04-2013, 11:53   #196 (permalink)
Member: 737187
Thanks to advance box team
box type : Atf nitro
11:09:47 : Box firmware : Logicore 10.3.30
11:09:47 : Software version : V9.40
11:09:47 : Advancebox sn :
11:09:47 : Box status : Activated
11:09:47 : ================================================
11:09:47 : Box successfully initialized
11:09:47 :
11:09:47 : Vbatt powering down <<<<
11:09:52 : Vbatt powering up >>>>
11:09:52 : Set vccio level done
11:09:52 : Set bsi load done
11:09:59 : ================================================== ====
11:09:59 : Lumia test point connection module
11:09:59 :
11:09:59 : 1. Do not use the phone"s battery
11:09:59 : 2. Connect the soldered tp connections to atf box
11:09:59 : 3. Disconnect the usb cable and wait until the
11:09:59 : The atf software will tell you to connect the usb.
11:09:59 :
11:10:07 :
11:10:07 : Interface reset ok!
11:10:07 : Reading platform information...
11:10:07 : Selecting active handle...
11:10:07 : Select handle ok!
11:10:07 : Sending ping...
11:10:07 : Ping reply ok!
11:10:07 :
11:10:07 : Lumia 710 detected (boot damaged)
11:10:07 : Use repair boot to fix this phone
11:10:07 :
11:10:07 : Storage device information
11:10:07 : Manufacturer id: 90
11:10:07 : Application id : 014a
11:10:07 : Product name : Hynix
11:10:07 : Product rev : 5d
11:10:07 : Product sn : 0054b490
11:10:07 :
11:10:07 : Protection information
11:10:07 : Write protect a: Off
11:10:07 : Write protect b: Off
11:10:07 :
11:10:07 : Writing mbr...
11:10:07 : Write success!
11:10:07 : Writing sec_boot...
11:10:36 : Write success!
11:10:37 : Writing osbl...
11:12:00 : Write success!
11:12:00 :
11:12:00 : Boot images written successfully!
11:12:00 :
11:12:00 : Total elapsed time 00:02:01
Old 01-05-2013, 13:14   #197 (permalink)
Member: 82249
Sonork: 100.114416
Lumia Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Storage Device Information
Manufacturer ID: 90
Application ID : 014A
Product Name : HYNIX
Product Rev : 5C
Product SN : 001A5FFB
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Minutes...
Patch Bit Found...
Total Patch Bits Found: 1
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:05:09
Old 01-07-2013, 18:15   #198 (permalink)
Member: 515130
LUMIA 710 REPAIR BOOT SUCCESSFULLY
THANKS ATF TEAM
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 710 Detected (Boot Damaged)
Use REPAIR BOOT to Fix this Phone
Manufacturer ID: 90
Product Rev : 5D
Product SN : 0FE563BC
Writing MBR...
Write Success!
Writing SEC_BOOT...
Write Success!
Writing OSBL...
Write Success!
BOOT Images Written Successfully!
Total Elapsed Time 00:01:35
The Following User Says Thank You to shahzad-0004 For This Useful Post:
Old 01-19-2013, 14:44   #199 (permalink)
Member: 628369
Sonork: 100.1609794
Lumia 800 TOSHIBA Chip unlock done after writing QUALCOM boot with ATF Big.
FOUND: Qualcomm MMC Storage USB Device
Mounted Drive Letter: 1
MBR Entry[0]:
Flags : 128
Type : 0x4D - SEC_BOOT
Starting Sector: 0x00000001
Sector Count : 0x000003E8
MBR Entry[1]:
Flags : 0
Type : 0x46 - OSBL
Starting Sector: 0x000003E9
Sector Count : 0x00000BB8
MBR Entry[2]:
Flags : 0
Type : 0x0C - AMSS_ADSP
Starting Sector: 0x00000FA1
Sector Count : 0x000493E0
EBR Entry[0]:
Flags : 0
Type : 0xEF - PMM
Starting Sector: 0x0004A386
Sector Count : 0x00000080
EBR Entry[1]:
Flags : 0
Type : 0x58 - ENC_STORAGE_A
Starting Sector: 0x0004A406
Sector Count : 0x00001800
EBR Entry[2]:
Flags : 0
Type : 0x4A - ENC_STORAGE_B
Starting Sector: 0x00060000
EBR Entry[3]:
Flags : 0
Type : 0x4B - ENC_STORAGE_C
Starting Sector: 0x00061800
EBR Entry[4]:
Flags : 0
Type : 0x48 - WP_OS
Starting Sector: 0x00080000
Sector Count : 0x01D4CFFF
Please wait for 15-20 Seconds...
Patch Bit Found...
Patching AMSS...
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:00:21
Old 01-19-2013, 14:44   #200 (permalink)
Member: 628369
Sonork: 100.1609794
MBR Entry[0]:
Flags : 128
MBR Entry[1]:
Flags : 0
Type : 0x46 - OSBL
MBR Entry[2]:
Flags : 0
EBR Entry[0]:
Flags : 0
Type : 0xEF - PMM
EBR Entry[1]:
Flags : 0
EBR Entry[2]:
Flags : 0
EBR Entry[3]:
Flags : 0
EBR Entry[4]:
Flags : 0
Type : 0x48 - WP_OS
Patch Bit Found...
Patching AMSS...
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Old 01-23-2013, 06:07   #201 (permalink)
Member: 1293050
Sonork: 100.1625975
boot repaired
but flash is didnt pass anyway thanks
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 710 Detected
Manufacturer ID: 90
Product Rev : 5D
Product SN : 056A92E4
Writing MBR...
Write Success!
Writing SEC_BOOT...
Write Success!
Writing OSBL...
Write Success!
Total Elapsed Time 00:01:39
Selected VPL File:
RM803_059M5W4_1600.3031.8773.12121_021.vpl
Variant Details : Nokia 710 RM-803 Country Variant Russia RU BLACK_BLACK V4
Software Version : 1600.3031.8773.12121
Product Type : RM-803
Product Code : 059M5W4
Variant Version : 021
Old 01-23-2013, 09:39   #202 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
Windows Phone Flashing Started
OSBL File Found:
RM801_12w22_1_prod_generic_nokia_osbl.esco
AMSS File Found:
RM801_12w22_1_prod_generic_amss.esco
ADSP File Found:
RM801_12w22_1_prod_generic_adsp.esco
WPOS File Found:
RM801_12221_prod_753_02_boot.esco
USER AREA ERASE File Found:
RM801_12w22_1_prod_generic_user_area_erase.esco
Windows Phone Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 8 more
seconds
Sending OSBL Certificate
HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E
Certificate Size: 452 Bytes
Status : WRITE OSBL CERTIFICATE SUCCESS
Sending OSBL Data Blocks
[BLOCK 1 0x00000000~0x000EA227]
Data Size: 0x000EA228 Bytes
SHA-256 : 9F4677ED1FBE63D145267113655B48FB
---------- : 2E0DCC7376A77735EF0969024D03761B
Status : OSBL WRITE SUCCESS
Sending AMSS Certificate
Certificate Size: 449 Bytes
Status : WRITE AMSS CERTIFICATE SUCCESS
Sending AMSS Data Blocks
(Please Wait for 25 Seconds...)
Status : AMSS WRITE SUCCESS
Sending ADSP Certificate
Status : WRITE ADSP CERTIFICATE SUCCESS
Sending ADSP Data Blocks
Status : ADSP WRITE SUCCESS
Sending WPOS Certificate
Certificate Size: 1604 Bytes
Status : WRITE WPOS CERTIFICATE SUCCESS
Sending WPOS Data Blocks
[BLOCK 1 0x00000000~0x00FFFFFF]
Data Size: 0x01000000 Bytes
SHA-256 : 8DAEBD7507BB9053A1BD5877A6BAB349
---------- : 879B83BF5B590D80CD7D5676614EF09C
Status : WPOS WRITE SUCCESS
[BLOCK 2 0x01000000~0x016573FF]
Data Size: 0x00657400 Bytes
SHA-256 : 636E39B67E44388083843721AFE60468
---------- : 8157E1CC00D20C467BF66A44EB1163D2
[BLOCK 3 0x01697400~0x01FFFFFF]
Data Size: 0x00968C00 Bytes
SHA-256 : 86CC5FEC10EDF7E293CAEB443C47DCE3
---------- : 791A7E5FFD188DA1A384F99BC1F5365D
[BLOCK 4 0x02000000~0x02FFFFFF]
SHA-256 : 5052B5B9A4F9DBD5AEA6B496781C779F
---------- : FB6CFA565819D9311E463BBD74C91133
[BLOCK 5 0x03000000~0x03FFFFFF]
SHA-256 : 909BF27051245B37DD4613FCC33577BD
---------- : 3DEBDE316409D4E8E7A5F30BA9621045
[BLOCK 6 0x04000000~0x04FFFFFF]
SHA-256 : 5F0EA31C4F7AA32CA823D3527FD1F845
---------- : 298A11B91A9B78CBDBF4363D14509343
[BLOCK 7 0x05000000~0x05FFFFFF]
SHA-256 : FFEF87B3A2CBAC9975BA879445FD2350
---------- : 0F47DA66B7C0C61C477DEB17FDB69E9C
[BLOCK 8 0x06000000~0x06FFFFFF]
SHA-256 : 16B60F1384EB9486484BCC98C5576CEB
---------- : 5A87B4F40B4B40E47A5DED760BF00A45
[BLOCK 9 0x07000000~0x07FFFFFF]
SHA-256 : BDC4F777CAA1C1E5B61386D4543182D1
---------- : DA1F342975F5D117AC133B88CE8D741D
[BLOCK 10 0x08000000~0x08FFFFFF]
SHA-256 : E4F45FE1DE8BC653BC6F043A6F3F0842
---------- : A8F020C6920459D84C5EE4A96F40062D
[BLOCK 11 0x09000000~0x09FFFFFF]
SHA-256 : 42D72828A976944AF657B89FDFA7C360
---------- : F69D73E87332AC3C0F213BF66DF9CA5A
[BLOCK 12 0x0A000000~0x0AFFFFFF]
SHA-256 : DE4D3E816BB38FC125B3390AD3DF0F01
---------- : B91D5A07D0E59EECE75074773A68C75B
[BLOCK 13 0x0B000000~0x0BFFFFFF]
SHA-256 : 73981A4C22FDB2F0A010DDF79329E4FB
---------- : F965C885A076D084273336152B71891D
[BLOCK 14 0x0C000000~0x0CFFFFFF]
SHA-256 : 54B7BE0A8F1E6BA302095FC8539E9F88
---------- : 01CA36578A2709BEE0482E627291191B
[BLOCK 15 0x0D000000~0x0DFFFFFF]
SHA-256 : A8A4F00438C34DE305AF2D14441231C2
---------- : 19CA8D570698E125767BA2833ED9AB44
[BLOCK 16 0x0E000000~0x0EFFFFFF]
SHA-256 : C3276CC18B17B1C52F4697D250E27F5F
---------- : BFDA42B8E89C7D3103E4A7FF16EF2459
[BLOCK 17 0x0F000000~0x0FFFFFFF]
SHA-256 : 42F4A7DA4BFD498DA0CE21EFF8156DAF
---------- : 78D209DBBB3E1EA9AF5FE3BD00D6E74C
[BLOCK 18 0x10000000~0x10FFFFFF]
SHA-256 : 3F0624474EDF5FDF69DE0F51E6B9220A
---------- : C3FFAD0227D152785AF2FA59EF583AE9
[BLOCK 19 0x11000000~0x11FFFFFF]
SHA-256 : 1F895EF4AB725B0ED1ACD784DD8667F6
---------- : 54EFBCA69A0E15379A07158BAEC70D9D
[BLOCK 20 0x12000000~0x12FFFFFF]
SHA-256 : 6DF46CBB5FC27220AA43B28A30172402
---------- : 318B62A12BB0938A99EB85B916707061
[BLOCK 21 0x13000000~0x13FFFFFF]
SHA-256 : BB7F88F44C5291B111D7BDA00DEB578C
---------- : F524BC42D5409D36781DA6DFC3F79900
[BLOCK 22 0x14000000~0x14FFFFFF]
SHA-256 : 3E33F69C7CEC593FFA59965490C645CB
---------- : D33CDB598E1BA9B9BAB51A7EB64D0CF4
[BLOCK 23 0x15000000~0x15FFFFFF]
SHA-256 : F37BFBDE1DCEB3EA07A68C49174C1B95
---------- : 6B0F137A77F05605E3AE754D987EEED1
[BLOCK 24 0x16000000~0x16FFFFFF]
SHA-256 : 5E77E373CF751586AFB95623B7A30042
---------- : F980A05791A2F903B3A146E9EB101FB1
[BLOCK 25 0x17000000~0x17DF0DFF]
Data Size: 0x00DF0E00 Bytes
SHA-256 : B8A5CA386A6907AF4B0B9FB716D86474
---------- : 9E2B6F1DF2EA51DFE98BF0269E476E81
Sending USER AREA ERASE Certificate
Certificate Size: 396 Bytes
Status : WRITE ERASE CERTIFICATE SUCCESS
Erasing USER AREA
Status : ERASE SUCCESS
Flashing Done!
Total Flashing Time (Erase + Flashing) : 00:03:34
Old 02-07-2013, 09:36   #203 (permalink)
Crazy Poster
Member: 1613857
lumai 800 unlock done with atf
here is log ================================================== ====
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 00194992
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:28
The Following User Says Thank You to ashish308775 For This Useful Post:
Old 03-05-2013, 11:37   #204 (permalink)
abuqatadh's Avatar
Member: 397296
lumia 710 RM-809 unlock by usb done
21:54:00 : ======================================================
21:54:00 :              Windows Phone Lumia Flasher
21:54:00 :
21:54:00 : If the Phone is ALIVE
21:54:00 :   1. Power On the Phone and Connect it to the USB Port
21:54:00 :
21:54:00 : If the Phone is DEAD
21:54:00 :   1. Press and Hold the VOLUME UP button
21:54:00 :   2. Connect it to the USB Port while still Pressing
21:54:00 :      the VOLUME UP button
21:54:00 :   3. Continue to Press the VOLUME UP button for 8 more
21:54:00 :      seconds
21:54:00 :
21:54:06 :
21:54:06 : ================================================
21:54:06 :             Basic Phone Information
21:54:06 : SW Version             : 1600.3030.8773.12120
21:54:07 : IMEI Plain               : 359333040299606
21:54:07 : HW Version            : 112.1402.2.1
21:54:07 : Phone Type            : RM-809
21:54:07 : Product Code         : 059L3Q9
21:54:08 : Basic Product Code: 059L3Q7
21:54:08 : Module Code          : 0205040
21:54:08 : PSN Number           : MOL229125
21:54:09 : NCSD Version         : 1.9
21:54:09 : Variant Information:VAR T-MOBILE BLACK
21:54:09 :
21:54:09 : ================================================
21:54:09 :            Extended Phone Information
21:54:09 : Public ID           : 5877EF9C89D612AB328A44A2DFD98F4D
21:54:09 : Wireless Lan ID: 94:00:70:63:27:EB:00:00
21:54:10 : Bluetooth ID     : 94:00:70:63:08:AD:00:00:00:00:00:00
21:54:10 :
21:54:21 : Rebooting to OSBL MODE
21:54:27 :
21:54:27 : Sending OSBL Certificate
21:54:27 : HASH: C72DBA3ABED42215584093FA9DE247381D6062B4
21:54:27 : Certificate Size: 452 Bytes
21:54:28 : Status     : WRITE OSBL CERTIFICATE SUCCESS
21:54:28 :
21:54:28 : Sending OSBL Data Blocks
21:54:28 : [BLOCK 1 0x00000000~0x000D5227]
21:54:28 : Data Size: 0x000D5228 Bytes
21:54:28 : SHA-256 : C603E58395ED18036FAE54480980C874
21:54:28 : ----------  : 730B725073658C1DA8123C9B639F625A
21:54:30 : Status     : OSBL WRITE SUCCESS
21:54:30 :
21:54:31 : Flashing Done!
21:54:31 : Total Flashing Time (Erase + Flashing) : 00:00:03
21:54:48 :
21:54:48 : FOUND: Qualcomm MMC Storage USB Device
21:54:48 : Mounted Drive Letter: 2
21:54:48 :
21:54:48 : MBR Entry[0]:
21:54:48 :         Flags : 128
21:54:48 :         Type : 0x4D - DBL
21:54:48 :         Starting Sector: 0x00000001
21:54:48 :         Sector Count   : 0x000003E8
21:54:48 : MBR Entry[1]:
21:54:48 :         Flags : 0
21:54:48 :         Type : 0x46 - OSBL
21:54:48 :         Starting Sector: 0x000003E9
21:54:48 :         Sector Count   : 0x00000BB8
21:54:48 : MBR Entry[2]:
21:54:49 :         Type : 0x0C - AMSS_ADSP
21:54:49 :         Starting Sector: 0x00000FA1
21:54:49 :         Sector Count   : 0x000493E0
21:54:49 : EBR Entry[0]:
21:54:49 :         Flags : 0
21:54:49 :         Type : 0xEF - PMM
21:54:49 :         Starting Sector: 0x0004A386
21:54:49 :         Sector Count   : 0x00000080
21:54:49 : EBR Entry[1]:
21:54:49 :         Type : 0x58 - ENC_STORAGE_A
21:54:49 :         Starting Sector: 0x0004A406
21:54:49 :         Sector Count   : 0x00001800
21:54:50 : EBR Entry[2]:
21:54:50 :         Flags : 0
21:54:50 :         Type : 0x4A - ENC_STORAGE_B
21:54:50 :         Starting Sector: 0x00060000
21:54:50 :         Sector Count   : 0x00001800
21:54:50 : EBR Entry[3]:
21:54:50 :         Type : 0x4B - ENC_STORAGE_C
21:54:50 :         Starting Sector: 0x00061800
21:54:51 : EBR Entry[4]:
21:54:51 :         Flags : 0
21:54:51 :         Type : 0x48 - WP_OS
21:54:51 :         Starting Sector: 0x00080000
21:54:51 :         Sector Count   : 0x00E10FFF
21:54:51 :
21:54:51 :
21:54:51 :
21:54:51 : Dumping AMSS FAT16 Region
21:54:51 : Please wait for 15-20 Seconds...
21:55:08 : Patch Bit Found...
21:55:08 : Total Patch Bits Found: 2
21:55:08 : Patching AMSS...
21:55:11 :
21:55:11 :
21:55:11 : SP Unlock Done!
21:55:11 :
21:55:11 : PIN: 00000000
21:55:11 : PUK: 0000000000
21:55:11 :
21:55:11 : Total Elapsed Time 00:00:23
Old 03-11-2013, 03:06   #205 (permalink)
sadermo's Avatar
Member: 1026340
Sonork: 1621159
710 dead.... done
Old 03-14-2013, 22:00   #206 (permalink)
jatchaminda's Avatar
Member: 661090
Sonork: 100.1616818
Lumia 800 Dead Boot Done
Old 03-16-2013, 13:53   #207 (permalink)
Member: 672891
hi ATF team,
i need your help.
i received lumia 710 no power.
customer said just suddenly lost power.
no history of water damaged nor fell.
i used atf to writing boot it success but still no power
here's the logs
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 710 Detected
Manufacturer ID: 90
Product Rev : 5D
Product SN : 001A10E0
Writing MBR...
Write Success!
Writing DBL...
Write Success!
Writing OSBL...
Write Success!
Total Elapsed Time 00:01:40
after that i flashed the mobile using usb cable but unfortunately still no respone on flashing.
Pls give me an idea for this mobile.
tia
Old 04-04-2013, 23:36   #208 (permalink)
Member: 52847
Originally Posted by gsmshamim1 View Post
i am all ready successful unlock lumia 810.best box atf for nokia all latest model.
HOW YOU DO THAT THIS PHONE NOT ON THE LIST
Old 04-19-2013, 13:36   #209 (permalink)
Danish Shafiq's Avatar
Member: 1118710
Sonork: 100.1604414
Smile Lumia 800 Unlock Done With TP
Old 05-09-2013, 11:35   #210 (permalink)
zlyden14's Avatar
Member: 254638
Originally Posted by Abzal View Post
No, don't found driver QCOM, like on the picture
i repair boot lumia 800.lumia dont pawer on,only vibro!!!
ERROR: Data Rejected at SEQ 0x3
Status : WRITE OSBL CERTIFICATE FAILED
Page generated in 0.37405 seconds with 11 queries
