Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 09-15-2012, 21:30   #16 (permalink)
vali.rusu's Avatar
Member: 41354
Congratulations for this update.
I have BIG PROBLEM.
I have a Nokia 710 that was broken by soft (wrong unlock) because today I was first to dissasamby.
I connected ok. We communicate with the device just like in post #5.
I did both operations (like in post nr 5), but I don't disconnected the device and I finally gave ... and SP UNLOCK.
After disconnecting the device I tried to start it, it vibrated (like when it was broken), BUT NON'T START OK.
I connected again to atf, communicate ok, and I repeated operations after each oprations (like in post 5) I tried to start but does not start, AND NOT VIBRATE - nothing.
If I try conect to PC this can not recognize- nothing.
Now I have a Lumia 710, dead, which connects with the ATF by TP, but otherwise the phone will not start.
I mention that I worked today morning with v 9.10, on the night I saw appeared v9.11.
I did not do well?
What is the correct order of operations?
What should I do?
I mention that I do not know which version of software will phone when they came to me dead, but if the PC can not recognize you can not make them flash.
Valy
Old 09-15-2012, 23:36   #17 (permalink)
RedeYeS's Avatar
Member: 36706
Sonork: 100.58560
Originally Posted by RedeYeS View Post
lumia 801
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Storage Device Information
Manufacturer ID: 90
Application ID : 014A
Product Name : HYNIX
Product Rev : 5C
Product SN : 07D58CB1
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Mintues...
WARNING: Patch Bit NOT FOUND!
Maybe Phone is already UNLOCKED!
Total Elapsed Time 00:04:27
but phone locked
solved after flashing with known / debranded amss :
Lumia Test Point Connection Module
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Patch Byte Found...
Total Patch Bits Found: 1
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:33
Thanks guys
Old 09-16-2012, 03:24   #18 (permalink)
Advance-Box's Avatar
Member: 651945
@vali.rusu
You need to Fix Boot , then SP Unlock after.
For Fixing 710, make sure you select the following Options:
After you repair boot with the 3 Options Checked Above, your phone should be
detected by Windows as NOKIA USB Device (DLOAD). DLOAD allows you to flash
the phone with a complete firmware from Navifirm.
If your phone fails to boot after Repairing the Boot, then you should try to remove
the wires which you connected to the phone. Too much capacitance on the TP
lines will sometimes cause the phone not to boot (wire quality and length).
Check the TP area, make sure the RED/YELLOW and the BLUE resistors are
connected properly to the PCB and was not detached while you were trying to solder
wires to it.
Check the GREEN TP area for short circuit.
The Following 8 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-16-2012, 03:26   #19 (permalink)
Member: 651945
@noor012345
Yes you can, just need to make sure you connected the wires correctly to the TP
Locations.
Also, avoid using Long and thick wires.
Be sure to flash the phone with Known Navifirm Version (use old version firmware) so
that you will increase your chance of success.
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-16-2012, 05:30   #20 (permalink)
noor012345's Avatar
Member: 861464
Sonork: 100.1597346 noor
ERROR: Cannot Initialize Module!
Please click Reset Box Button...
Old 09-16-2012, 07:15   #21 (permalink)
noor012345's Avatar
Member: 861464
ERROR: Sending Boot Failed!
Check your Test Point Soldering!
Total Elapsed Time 00:00:02
successfull unlock br help me
Old 09-16-2012, 08:40   #22 (permalink)
vali.rusu's Avatar
Member: 41354
Originally Posted by Advance-Box View Post
@vali.rusu
wires to it.
Thx for reply,
monday morning i will test again. the wires leght is almost 10 cm from box to the phone, and first I make a test tp conection, but... never knows
I will post the rezult
VALY
Old 09-16-2012, 08:55   #23 (permalink)
Member: 86994
Sonork: 100.1584487
Successfully done lumia 800
THANX ATF TEAM FOR THIS WONDERFUL UPDATE
I HAVE SUCCESSFULLY UNLOCK LUMIA 800 DLOAD WITH 9.11
KEEP IT UP
QAISER
23:45:04 : ================================================
23:45:04 : Advance Turbo Flasher Found
23:45:04 : Driver Version : 00020824
23:45:04 : Library Version : 00030207
23:45:06 : Box Type : ATF Nitro
23:45:06 : Box Firmware : LogiCore 10.3.30
23:45:06 : Software Version : v9.11
23:45:06 : AdvanceBox SN : 8E61EB68E706DE7ABE7E37B9
23:45:06 : Box Status : ACTIVATED
23:45:06 : ================================================
23:45:06 : Box Successfully Initialized
23:45:06 :
23:45:06 : VBATT Powering Down <<<<
23:45:10 : VBATT Powering Up >>>>
23:45:10 : SET VCCIO Level Done
23:45:10 : SET BSI Load Done
23:45:12 : ================================================== ====
23:45:12 : Lumia Test Point Connection Module
23:45:12 :
23:45:12 : 1. DO NOT USE THE PHONE"S BATTERY
23:45:12 : 2. Connect the Soldered TP Connections to ATF Box
23:45:12 : 3. Disconnect the USB Cable and Wait until the
23:45:12 : the ATF Software will tell you to Connect the USB.
23:45:12 :
23:45:19 :
23:45:19 : Interface Reset OK!
23:45:19 : Reading Platform Information...
23:45:19 : Selecting Active Handle...
23:45:19 : Select Handle OK!
23:45:19 : Sending Ping...
23:45:19 : Ping Reply OK!
23:45:19 :
23:45:19 : Lumia 800/800C Detected
23:45:19 :
23:45:19 : Storage Device Information
23:45:19 : Manufacturer ID: 90
23:45:19 : Application ID : 014A
23:45:19 : Product Name : HYNIX
23:45:19 : Product Rev : 5C
23:45:19 : Product SN : 002E59A8
23:45:19 :
23:45:19 : Protection Information
23:45:19 : Write Protect A: OFF
23:45:19 : Write Protect B: OFF
23:45:19 :
23:45:19 :
23:45:19 : Dumping AMSS FAT16 Region
23:45:19 : Please wait for 2-4 Mintues...
23:47:04 : ================================================== ====
23:47:04 : Lumia Test Point Connection Module
23:47:04 :
23:47:04 : 1. DO NOT USE THE PHONE"S BATTERY
23:47:04 : 2. Connect the Soldered TP Connections to ATF Box
23:47:04 : 3. Disconnect the USB Cable and Wait until the
23:47:04 : the ATF Software will tell you to Connect the USB.
23:47:04 :
23:47:06 :
23:47:06 : Interface Reset OK!
23:47:06 : Reading Platform Information...
23:47:06 : Selecting Active Handle...
23:47:06 : Select Handle OK!
23:47:06 : Sending Ping...
23:47:06 : Ping Reply OK!
23:47:06 :
23:47:06 : Lumia 800/800C Detected
23:47:06 :
23:47:06 : Storage Device Information
23:47:06 : Manufacturer ID: 90
23:47:06 : Application ID : 014A
23:47:06 : Product Name : HYNIX
23:47:06 : Product Rev : 5C
23:47:06 : Product SN : 002E59A8
23:47:06 :
23:47:06 : Protection Information
23:47:06 : Write Protect A: OFF
23:47:06 : Write Protect B: OFF
23:47:06 :
23:47:06 :
23:47:06 : Dumping AMSS FAT16 Region
23:47:06 : Please wait for 2-4 Mintues...
23:51:08 : Patch Byte Found...
23:51:08 : Total Patch Bits Found: 1
23:51:08 : Patching AMSS...
23:51:08 : Patch OK!
23:51:08 :
23:51:08 : SP Unlock Done!
23:51:08 :
23:51:08 : PIN: 00000000
23:51:08 : PUK: 0000000000
23:51:08 :
23:51:08 : Total Elapsed Time 00:05:56
Old 09-16-2012, 10:59   #24 (permalink)
Member: 765909
Sonork: 100.1608098
lumina 800 done but still ask pin code
where is problem?
[IMG][/IMG]
Old 09-16-2012, 11:59   #25 (permalink)
Member: 391664
Sonork: 100.1580390
Lumia 800 Unlock Done!SP Unlock Done!
PHP Code:
14:59:36 : ======================================================
14:59:36 :        Lumia Test Point Connection Module
14
14:59:36 :
14:59:36 1. DO NOT USE THE PHONE"S BATTERY
14:59:36 : 2. Connect the Soldered TP Connections to ATF Box
14:59:36 : 3. Disconnect the USB Cable and Wait until the
14:59:36 :    the ATF Software will tell you to Connect the USB.
14:59:36 :
14:59:40 : ERROR: Sending Boot Failed!
14:59:40 : Check your Test Point Soldering!
14:59:40 :
14:59:40 : Total Elapsed Time 00:00:04
15:00:08 : ======================================================
15:00:08 :        Lumia Test Point Connection Module
15:00:08 :
15:00:08 : 1. DO NOT USE THE PHONE"
S BATTERY
15
:00:08 2. Connect the Soldered TP Connections to ATF Box
15
:00:08 3. Disconnect the USB Cable and Wait until the
15
:00:08 :    the ATF Software will tell you to Connect the USB
15:00:08 :
15:00:08 ERRORCannot Initialize Module!
15:00:08 Please click Reset Box Button...
15:00:08
15:00:08 Total Elapsed Time 00:00:00
15
:00:37 : ======================================================
15:00:37 : ======================================================
15:00:37 :        Lumia Test Point Connection Module
15
15:00:37 :
15:00:37 1. DO NOT USE THE PHONE"S BATTERY
15:00:37 : 2. Connect the Soldered TP Connections to ATF Box
15:00:37 : 3. Disconnect the USB Cable and Wait until the
15:00:37 :    the ATF Software will tell you to Connect the USB.
15:00:37 :
15:00:37 : ERROR: Cannot Initialize Module!
15:00:37 : Please click Reset Box Button...
15:00:37 :
15:00:37 : Total Elapsed Time 00:00:00
15:00:47 : ================================================
15:00:47 :           Advance Turbo Flasher Found
15:00:47 : Driver Version       : 00020819
15:00:47 : Library Version      : 00030207
15:00:49 : Box Type               : ATF Lightning
15:00:49 : Box Firmware        : LogiCore 10.3.30
15:00:49 : Software Version  : v9.10
15:00:49 : AdvanceBox SN    : E8CC25D8BAE2C1D6FA9E42C9
15:00:49 : Box Status            : ACTIVATED
15:00:49 : ================================================
15:00:49 :           Box Successfully Initialized
15:00:49 :
15:00:49 : VBATT Powering Down <<<<
15:00:53 : VBATT Powering Up   >>>>
15:00:53 : SET VCCIO Level Done
15:00:53 : SET BSI Load Done
15:00:57 : ======================================================
15:00:57 :        Lumia Test Point Connection Module
15:00:57 :
15:00:57 : 1. DO NOT USE THE PHONE"
S BATTERY
15
:00:57 2. Connect the Soldered TP Connections to ATF Box
15
:00:57 3. Disconnect the USB Cable and Wait until the
15
:00:57 :    the ATF Software will tell you to Connect the USB
15:00:57 :
15:01:00
15:01:00 : Interface Reset OK!
15:01:00 Reading Platform Information...
15:01:00 Selecting Active Handle...
15:01:00 Select Handle OK!
15:01:00 Sending Ping...
15:01:00 Ping Reply OK!
15:01:00
15:01:00 Lumia 800/800C Detected
15
:01:00
15:01:00 Storage Device Information
15
:01:00 Manufacturer ID90
15
:01:00 Application ID 014A
15
:01:00 Product Name   HYNIX
15
:01:00 Product Rev    5C
15
:01:00 Product SN     003A71DD
15
:01:00
15:01:00 Protection Information
15
:01:00 Write Protect AOFF
15
:01:00 Write Protect BOFF
15
:01:00
15:01:00
15:01:00 Dumping AMSS FAT16 Region
15
:01:00 Please wait for 2-4 Mintues...
15:05:04 Patch Bit Found...
15:05:04 Total Patch Bits Found1
15
:05:04 Patching AMSS...
15:05:04 Patch OK!
15:05:04
15:05:04
15:05:04
15:05:04 PIN00000000
15
:05:04 PUK0000000000
15
:05:04
15:05:04 Total Elapsed Time 00:04:06
Old 09-16-2012, 12:40   #26 (permalink)
Member: 86994
Sonork: 100.1584487
Originally Posted by maplegsm View Post
PHP Code:
14
14:59:36 :
14:59:36 :
14:59:40 :
15:00:08 :
S BATTERY
15
15
15
15:00:08 :
15:00:08
15
15
15:00:37 :
15:00:37 :
15:00:37 :
15:00:49 :
15:00:57 :
S BATTERY
15
15
15
15:00:57 :
15:01:00
15:01:00
15
:01:00
15
15
15
15
15
15
:01:00
15
15
15
:01:00
15:01:00
15
15
15:05:04 Patch OK!
15:05:04
15:05:04
15:05:04
15
15
:05:04
Hi Umer
can u plz share the firmware version of ur lumia 800..
as i unlocked 1 successfully but its not accepting code
Thanx and regards
Old 09-16-2012, 13:53   #27 (permalink)
Member: 391664
Sonork: 100.1580390
Lightbulb
Originally Posted by qaiser78 View Post
Hi Umer
Thanx and regards
what u did just boot repair + direct unlock ?
flash with same PC code with latest FW or try to use other down same PC code FW
Old 09-16-2012, 14:07   #28 (permalink)
Member: 1761688
Sonork: 100.1603147
error block write failed at 0x00000003
HI
I have a lumia 800 dead boot just one vibrate and not write osbl of frimware
when write sec_boot with error block write failed at 0x00000003 face
version 9.10 and 9.11
all is ok
 wires to it.
Old 09-16-2012, 17:14   #29 (permalink)
UnlockingPoint's Avatar
Member: 1033807
not unlocked
the phone is locked but it always show this
16:13:47 :        Lumia Test Point Connection Module
16:13:47 : ======================================================
16:13:47 :
16:13:47 : 1. DO NOT USE THE PHONE"S BATTERY
16:13:47 : 2. Connect the Soldered TP Connections to ATF Box
16:13:47 : 3. Disconnect the USB Cable and Wait until the
16:13:47 :    the ATF Software will tell you to Connect the USB.
16:13:47 :
16:13:49 :
16:13:49 : Interface Reset OK!
16:13:49 : Reading Platform Information...
16:13:49 : Selecting Active Handle...
16:13:49 : Select Handle OK!
16:13:49 : Sending Ping...
16:13:49 : Ping Reply OK!
16:13:49 :
16:13:49 : Lumia 800/800C Detected
16:13:49 :
16:13:49 : Storage Device Information
16:13:49 : Manufacturer ID: 90
16:13:49 : Application ID : 014A
16:13:49 : Product Name   : HYNIX
16:13:49 : Product Rev    : 5C
16:13:49 : Product SN     : 08C32599
16:13:49 :
16:13:49 : Protection Information
16:13:49 : Write Protect A: OFF
16:13:49 : Write Protect B: OFF
16:13:49 :
16:13:49 :
16:13:49 : Dumping AMSS FAT16 Region
16:13:49 : Please wait for 2-4 Mintues...
16:18:06 :
16:18:06 : WARNING: Patch Bit NOT FOUND!
16:18:06 : Maybe Phone is already UNLOCKED!
16:18:06 :
16:18:06 : Total Elapsed Time 00:04:25
Old 09-16-2012, 17:23   #30 (permalink)
najegsm's Avatar
Member: 185396
Sonork: 100.1618832
nokia lumina 800 after dead boot not power on!!!!!!!!!!!
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 0010E280
Writing MBR...
Write Success!
Writing SEC_BOOT...
Write Success!
Writing OSBL...
Write Success!
BOOT Images Written Successfully!
Total Elapsed Time 00:01:38
dead boot ok no power same like befor when conect usb cable to flash only vibration all driver installed pls help me anyone!!!!!!!!!!!!
Page generated in 3.73368 seconds with 11 queries
