Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 09-16-2012, 20:03   #31 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Lumia DEAD BOOT REPAIR and UNLOCK ... "Thread for success logs"
Hi friends
take a look below for deatils of success unlocking of Lumia800.
Np at all.
all goes ok.
Spacial thanks goes to my friend X-Shadow ( advance-box ) as his guide line make me easy to done this job.
23:09:16 : ================================================== ====
23:09:16 : Lumia Test Point Connection Module
23:09:16 :
23:09:16 : 1. DO NOT USE THE PHONE"S BATTERY
23:09:16 : 2. Connect the Soldered TP Connections to ATF Box
23:09:16 : 3. Disconnect the USB Cable and Wait until the
23:09:16 : the ATF Software will tell you to Connect the USB.
23:09:16 :
23:09:18 :
23:09:18 : Interface Reset OK!
23:09:18 : Reading Platform Information...
23:09:18 : Selecting Active Handle...
23:09:18 : Select Handle OK!
23:09:18 : Sending Ping...
23:09:18 : Ping Reply OK!
23:09:18 :
23:09:18 : Lumia 800/800C Detected
23:09:18 :
23:09:18 : Storage Device Information
23:09:18 : Manufacturer ID: 90
23:09:18 : Application ID : 014A
23:09:18 : Product Name : HYNIX
23:09:18 : Product Rev : 5C
23:09:18 : Product SN : 00E7B486
23:09:18 :
23:09:18 : Protection Information
23:09:18 : Write Protect A: OFF
23:09:18 : Write Protect B: OFF
23:09:18 :
23:09:18 :
23:09:18 : Dumping AMSS FAT16 Region
23:09:18 : Please wait for 2-4 Mintues...
23:09:20 : ================================================== ====
23:09:20 : Lumia Test Point Connection Module
23:09:20 :
23:09:20 : 1. DO NOT USE THE PHONE"S BATTERY
23:09:20 : 2. Connect the Soldered TP Connections to ATF Box
23:09:20 : 3. Disconnect the USB Cable and Wait until the
23:09:20 : the ATF Software will tell you to Connect the USB.
23:09:20 :
23:09:22 :
23:09:22 : Interface Reset OK!
23:09:22 : Reading Platform Information...
23:09:22 : Selecting Active Handle...
23:09:22 : Select Handle OK!
23:09:22 : Sending Ping...
23:09:22 : Ping Reply OK!
23:09:22 :
23:09:22 : Lumia 800/800C Detected
23:09:22 :
23:09:22 : Storage Device Information
23:09:22 : Manufacturer ID: 90
23:09:22 : Application ID : 014A
23:09:22 : Product Name : HYNIX
23:09:22 : Product Rev : 5C
23:09:22 : Product SN : 00E7B486
23:09:22 :
23:09:22 : Protection Information
23:09:22 : Write Protect A: OFF
23:09:22 : Write Protect B: OFF
23:09:22 :
23:09:22 :
23:09:22 : Dumping AMSS FAT16 Region
23:09:22 : Please wait for 2-4 Mintues...
23:14:59 : Patch Byte Found...
23:15:00 : Total Patch Bits Found: 1
23:15:00 : Patching AMSS...
23:15:00 : Patch OK!
23:15:00 :
23:15:00 : SP Unlock Done!
23:15:00 :
23:15:00 : PIN: 00000000
23:15:00 : PUK: 0000000000
23:15:00 :
23:15:00 : Total Elapsed Time 00:05:43
Old 09-17-2012, 07:51   #32 (permalink)
Member: 361094
Sonork: 100.1597521
Thumbs up lumia 800 unlock done
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 000E3073
Patch Bit Found...
Patch Bit Found...
Total Patch Bits Found: 2
Patching AMSS...
Patch OK!
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:29
And gUd news for those when unlock done with atf and still ask pin code
u just enter 16 time 0 as u see on atf logs pin and puk code 000000
after accept code ur set w,ll b 100 unlock done.....thanks atf team u did nice job
Old 09-17-2012, 09:31   #33 (permalink)
Member: 1195046
lumia 800 unlock no ok hepl
Patch Byte Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Old 09-17-2012, 09:38   #34 (permalink)
Member: 1797426
10:19:16 : Box Status : ACTIVATED
10:19:16 : ================================================
10:19:16 : Box Successfully Initialized
10:19:17 :
10:19:17 : VBATT Powering Down <<<<
10:19:21 : VBATT Powering Up >>>>
10:19:21 : SET VCCIO Level Done
10:19:21 : SET BSI Load Done
10:19:28 : ================================================== ====
10:19:28 : Lumia Test Point Connection Module
10:19:28 :
10:19:28 : 1. DO NOT USE THE PHONE"S BATTERY
10:19:28 : 2. Connect the Soldered TP Connections to ATF Box
10:19:28 : 3. Disconnect the USB Cable and Wait until the
10:19:28 : the ATF Software will tell you to Connect the USB.
10:19:28 :
10:19:35 :
10:19:35 : Interface Reset OK!
10:19:35 : Reading Platform Information...
10:19:35 : Selecting Active Handle...
10:19:35 : Select Handle OK!
10:19:35 : Sending Ping...
10:19:35 : Ping Reply OK!
10:19:35 :
10:19:35 : Lumia 710 Detected
10:19:35 :
10:19:35 : Storage Device Information
10:19:35 : Manufacturer ID: 90
10:19:35 : Application ID : 014A
10:19:35 : Product Name : HYNIX
10:19:35 : Product Rev : 5D
10:19:35 : Product SN : 005E09E7
10:19:35 :
10:19:36 : Protection Information
10:19:36 : Write Protect A: OFF
10:19:36 : Write Protect B: OFF
10:19:36 :
10:19:36 :
10:19:36 : Dumping AMSS FAT16 Region
10:19:36 : Please wait for 2-4 Mintues...
10:23:37 : Patch Bit Found...
10:23:37 : Total Patch Bits Found: 1
10:23:37 : Patching AMSS...
10:23:37 : Patch OK!
10:23:37 :
10:23:37 : SP Unlock Done!
10:23:37 :
10:23:37 : PIN: 00000000
10:23:37 : PUK: 0000000000
10:23:37 :
10:23:37 : Total Elapsed Time 00:04:08
Thank you very much ATF Team!!!
Best regards!
Old 09-17-2012, 09:39   #35 (permalink)
Member: 765909
Sonork: 100.1608098
plz help me lumia800 done but still ask pin code
i try 8 time (0) now ask puk code help me mr angel
Old 09-17-2012, 09:54   #36 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
Try 8 times 0 again for Puk code as well.
Old 09-17-2012, 10:15   #37 (permalink)
Member: 765909
Sonork: 100.1608098
incorrect puk code
same problem help plz
Old 09-17-2012, 10:27   #38 (permalink)
Member: 643472
Sonork: 100.96901
incorrect puk code
Flash AMMS file of lower version downloaded from NaviFirm software. After unlock again...
Old 09-17-2012, 11:24   #39 (permalink)
Member: 765909
Sonork: 100.1608098
how to flash?
via usb?
or via tp?
Old 09-17-2012, 11:34   #40 (permalink)
ryumahon's Avatar
Member: 4021
flash it via usb sir.. download files from navifirm..
but i have same problem as yours... i did flashed it with the tested firmwares according to sir x-shadow but still INCORRECT PIN...
Old 09-17-2012, 13:59   #41 (permalink)
Member: 1043049
lumia 800 unlocked
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 0039FEC6
Patch Byte Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:32
Old 09-17-2012, 16:12   #42 (permalink)
itsmesoul's Avatar
Member: 416286
Sonork: 100.1622339
LUMIA 800 unlocked successfully Thanks ATF team
The Following User Says Thank You to itsmesoul For This Useful Post:
Old 09-17-2012, 16:53   #43 (permalink)
Member: 361094
Sonork: 100.1597521
after full flash try unlock again and if ask code enter 16 time 0 then unlock code will accept dear m test thz at morning and 100 working
Old 09-17-2012, 16:56   #44 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Hi, can any one share with pictures how to connect red and yellow wires to test point for Lumia 800? Do I have to remove golden test point contact to get it connected?
Sorry for maybe stupid question.
Thanks
Old 09-17-2012, 17:27   #45 (permalink)
roklat's Avatar
Member: 686535
Sonork: 1592667
17:00:52 : ================================================== ====
17:00:52 : Lumia Test Point Connection Module
17:00:52 :
17:00:52 : 1. DO NOT USE THE PHONE"S BATTERY
17:00:52 : 2. Connect the Soldered TP Connections to ATF Box
17:00:52 : 3. Disconnect the USB Cable and Wait until the
17:00:52 : the ATF Software will tell you to Connect the USB.
17:00:52 :
17:00:54 :
17:00:54 : Interface Reset OK!
17:00:54 : Reading Platform Information...
17:00:54 : Selecting Active Handle...
17:00:54 : Select Handle OK!
17:00:54 : Sending Ping...
17:00:54 : Ping Reply OK!
17:00:54 :
17:00:54 : Lumia 800/800C Detected
17:00:54 :
17:00:54 : Storage Device Information
17:00:54 : Manufacturer ID: 80
17:00:54 : Application ID : 0000
17:00:54 : Product Name :
17:00:54 : Product Rev : 0C
17:00:54 : Product SN : 00C40608
17:00:54 :
17:00:54 : Protection Information
17:00:54 : Write Protect A: OFF
17:00:54 : Write Protect B: OFF
17:00:54 :
17:00:54 :
17:00:54 : Dumping AMSS FAT16 Region
17:00:54 : Please wait for 2-4 Mintues...
17:05:24 : Patch Bit Found...
17:05:24 : Total Patch Bits Found: 1
17:05:24 : Patching AMSS...
17:05:25 : Patch OK!
17:05:25 :
17:05:25 : SP Unlock Done!
17:05:25 :
17:05:25 : PIN: 00000000
17:05:25 : PUK: 0000000000
17:05:25 :
17:05:25 : Total Elapsed Time 00:04:32
Page generated in 0.36788 seconds with 11 queries
