Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 09-17-2012, 20:14   #46 (permalink)
Member: 367678
Well done
Lumia 800 SP Unlock done
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Storage Device Information
Manufacturer ID: 90
Application ID : 014A
Product Name : HYNIX
Product Rev : 5C
Product SN : 00147A57
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Mintues...
Patch Byte Found...
Total Patch Bits Found: 1
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:27
Old 09-18-2012, 12:56   #47 (permalink)
Member: 765909
Sonork: 100.1608098
hi team flahing stuck where is problem ?
Windows Phone Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 8 more
seconds
Basic Phone Information
SW Version : 1600.2479.7740.11451
IMEI Plain : 3592890475*****
HW Version : 112.1402.2.3
Product Code : 059M0C7
Basic Product Code: 059J2N6
Module Code : 0205051
PSN Number : 005B635AB
NCSD Version : 1.5
Extended Phone Information
Public ID : F2428970CD18B82EE0F9F86DAA6A58D3
Wireless Lan ID: 94:3A:F0:61:BE:2F:00:00
Bluetooth ID : 94:3A:F0:61:96:F8:00:00:00:00:00:00
Rebooting to OSBL MODE [/QUOTE]
I press and hold Volume Up as software says, but every 30seconds phone vibrate short and not flash.
Old 09-18-2012, 14:19   #48 (permalink)
Member: 1800670
Sonork: 100.1620362
Lumia 800 unlock success
Lumia Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 000DABD0
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:05:01
Old 09-18-2012, 14:38   #49 (permalink)
vali.rusu's Avatar
Member: 41354
Originally Posted by Advance-Box View Post
@vali.rusu
You need to Fix Boot , then SP Unlock after.
For Fixing 710, make sure you select the following Options:
After you repair boot with the 3 Options Checked Above, your phone should be
detected by Windows as NOKIA USB Device (DLOAD). DLOAD allows you to flash
the phone with a complete firmware from Navifirm.
If your phone fails to boot after Repairing the Boot, then you should try to remove
the wires which you connected to the phone. Too much capacitance on the TP
lines will sometimes cause the phone not to boot (wire quality and length).
Check the TP area, make sure the RED/YELLOW and the BLUE resistors are
connected properly to the PCB and was not detached while you were trying to solder
wires to it.
Check the GREEN TP area for short circuit.
HELLO
THX for instruction ... the phone in ALIVE and WORK 100%, and I repair and unlocked and lumia 800.
thx so much
BUT.....Other LUMIA, Other PROBLEM
today came to me a Lumia 710 DEAD... nothing hapend if plug USB cable, pc don;t recognizes,,, nothing....
I opened phone and saw that someone was working on it, and missing resistance where TP (RED/YELLOW) sticks.
Pls tellme someone value for this resistance ???? may be I find in other phone and I change it.
It is possible that phone dont starts because this resistance misssing?
B R
V
Old 09-18-2012, 16:08   #50 (permalink)
Member: 1800670
Sonork: 100.1620362
other lumia 800 unlock success
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Name : 016G4B
Product Rev : 5C
Product SN : 000DA3D0
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:06:44
The Following User Says Thank You to GsmUnlockSource For This Useful Post:
Old 09-18-2012, 16:10   #51 (permalink)
Member: 246072
Lumia 800 RM-801 unlock done :)
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev    : 5C
Product SN     : 0A3F5E76
Patch Byte Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:05:06
Tks for the amazing update
Old 09-19-2012, 07:33   #52 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
>>>> Lumia 800 Unlocked <<<<
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 03B19D78
Patch Byte Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:25
Old 09-19-2012, 11:44   #53 (permalink)
roklat's Avatar
Member: 686535
Sonork: 1592667
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 02FA1940
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:36
Old 09-19-2012, 11:44   #54 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Lumia 710 rm-809 Boot Repair and Unlock done
Lumia 710 rm-809 Dead by Format Disk.
Repaired And Unlock Done
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 710 Detected (Boot Damaged)
Use REPAIR BOOT to Fix this Phone
Manufacturer ID: 90
Product Rev : 5D
Product SN : 0061ED5F
Boot Repair
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5D
Writing MBR...
Write Success!
Writing SEC_BOOT...
Write Success!
Writing OSBL...
Write Success!
BOOT Images Written Successfully!
Total Elapsed Time 00:01:36
Unlocking
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 710 Detected
Manufacturer ID: 90
Product Rev : 5D
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:02:15
The Following 2 Users Say Thank You to UNIQUEM For This Useful Post:
Old 09-19-2012, 14:33   #55 (permalink)
Member: 30455
THX ATF TEAM....good update
this ams RM801_12w22_prod_generic_amss.esco
sw verion.1750.0805.8773.12220_017
14:41:00 : Lumia 800/800C Detected
14:41:00 :
14:41:00 : Storage Device Information
14:41:00 : Manufacturer ID: 90
14:41:00 : Application ID : 014A
14:41:00 : Product Name : HYNIX
14:41:00 : Product Rev : 5C
14:41:00 : Product SN : 02357F40
14:41:00 :
14:41:00 : Protection Information
14:41:00 : Write Protect A: OFF
14:41:00 : Write Protect B: OFF
14:41:00 :
14:41:00 :
14:41:00 : Dumping AMSS FAT16 Region
14:41:00 : Please wait for 2-4 Mintues...
14:47:32 : Patch Byte Found...
14:47:32 : Total Patch Bits Found: 2
14:47:32 : Patching AMSS...
14:47:33 : Patch OK!
14:47:34 : Patch OK!
14:47:34 :
14:47:34 : SP Unlock Done!
14:47:34 :
14:47:34 : PIN: 00000000
14:47:34 : PUK: 0000000000
14:47:34 :
14:47:34 : Total Elapsed Time 00:06:36
Old 09-19-2012, 15:16   #56 (permalink)
Member: 34379
Manufacturer ID: 90
Product Rev : 5C
Product SN : 00B4EA50
Patch Byte Found...
Patch Byte Found...
Patching AMSS...
Patch OK!
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Old 09-19-2012, 17:33   #57 (permalink)
Advance-Box's Avatar
Member: 651945
Originally Posted by vali.rusu View Post
HELLO
thx so much
B R
V
Resistor on RED/YELLOW TP Location is 0 Ohms...
So just put a JUMPER wire or just put some solder lead on it to bridge the
Connection and it will be working again.
GREEN TP location resistor value does not matter... Phone will work even if you
removed the resistor.
BLUE TP location resistor resistor value does not matter... Phone will work even if you
So if you accidentally damaged the resistor or removed it from the
TP locations, you can easily fix it using the information I just shared.
B.R.
X-Shadow
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-19-2012, 22:58   #58 (permalink)
bendou's Avatar
Member: 165971
lumia 800 pin incorrect
phone is not unlocked yet but software show ok !!!
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 0112B2CA
Patch Byte Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:08:10
Old 09-20-2012, 09:42   #59 (permalink)
melyse's Avatar
Member: 28241
Thanks team .............................
File Type: jpg 564651_410743065641718_726137449_n.jpg (155.2 KB, 108 views)
Old 09-20-2012, 11:21   #60 (permalink)
Member: 711273
lumia 800 Unlock Done
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Name : @YNIX
Product Rev : 5C
Product SN : 05A0703C
Patch Byte Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:52
Page generated in 0.45327 seconds with 11 queries
