01-09-2013, 15:29 | #3 (permalink) |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | now giving error 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: Cannot Initialize Module! Please click Reset Box Button... |
01-09-2013, 15:39 | #4 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 00199CB9 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:27 |
01-10-2013, 21:36 | #9 (permalink) | |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | Quote:
does a update through zune relock? or only a full flash? can i make a flash with atf without flashing amms? or is the best solution to make your phone qualcomm? a update trhrough zune shouldn't overwrite qualcomm,right? so, i could unlock again without the need of soldering? | |
01-11-2013, 06:09 | #10 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
No Skip AMMS flash not possible in ATF as now Br - srinibas | |
