05-07-2013, 10:15 | #1 (permalink) | |
Freak Poster Join Date: Mar 2008
Member: 731116 Status: Offline Sonork: 100.1612132 Thanks Meter: 28 | Lumia800 tp repair after.flash ERROR: Data Rejected at SEQ 0x3 i use atf tp repair nokia dload . after use ATF flash but error. Quote:
05-08-2013, 03:47 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | You will get this error because: 1. Maybe your battery does not have enough charge since Phone was dead for long time already... Or 2. Maybe you left the TP wires connected (you should remove it before flashing). Or 3. Maybe you damaged some resistor while soldering (very rare unless you were not careful). Most probably is #1... As all the time in teamviewer I solved this same kind of problem with other users. So now just charge your phone for 30 minutes. Even if phone is dead, it should charge just as long as boot is already ok and repaired. Try first to charge via the USB of your PC, see if windows detect some new USB HID Device. If it detects, then charge phone in wall charger with original Nokia Charge and USB cable. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
05-08-2013, 07:14 | #5 (permalink) | |
Member: 731116 Status: Offline Sonork: 100.1612132 Thanks Meter: 28 | Quote:
