08-26-2013, 17:06 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lingkeji Try it like this: 1. Connect JTAG Wires to phone 2. Connect USB Cable to phone, BUT DO NOT CONNECT USB CABLE TO PC PORT 3. Click Restore Boot ---> software will say "waiting for 10 seconds..." at this point, connect USB Cable to PC PORT. |
08-27-2013, 06:54 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lingkeji Ok, you need to solder 1 more wire,, see attached Pinouts... Then you need to download v2 repair files: http://174.120.45.27/tmp/920_AFP_V2/ Just choose the correct RM-XXX for your phone... So solder another wire to the resistor in the pinout, and connect it to the ORANGE Wire as well... Zoomed! YES, YOU NEED TO REMOVE THE CPU SHIELD CAREFULLY!!! |
08-27-2013, 08:17 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lingkeji If you cannot halt your 920, then you need to solder to that resistor to make it Halt for you. What do you mean you cannot download? Those are Direct Links from ATF Server. If you cannot download then check your windows or you browser... There is no Problem on our server. |
08-27-2013, 09:14 | #11 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | I don't understand what you are talking about. ATF JTAG is the MOST SIMPLE and EASY JTAG SOFTWARE in the WORLD. You only have 3 buttons. Please tell me what is so hard about this: And why is it so hard for you to download from here? Index of /tmp/920_AFP_V2 Button Descriptions: [SELECT PHONE] <------ This button lets you Select a Phone "afp" file, example "920_RM-820_v2.afp" [RESET JTAG] <------- This button lets you Reset JTAG Connection [RESTORE BOOT] <------ This button lets you Restore the Boot of your phone and making it BOOTABLE again Here is direct links in case you don't understand how to use link above Lumia 920 RM-820 Lumia 920 RM-821 Lumia 920 RM-822 Lumia 920T RM-867 |
08-27-2013, 10:11 | #13 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @lingkeji For all lumia 920 which give an error: "cannot halt" You need to solder one more wire and use v2 repair files. If some phones can be repaired without to use v2 repair files, than it is okay as well. BR |
08-27-2013, 10:20 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | v1, v2, v3, v4 etc... All OK to use just as long as RM-XXX is matched to actual phone unit. Connect wire to resistor or NOT connect wire to resistor can work with v1, v2, v3, v4 etc... Just as long as RM-XXX is matches to actual phone unit. |
