01-24-2014, 16:21 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dubz
Member: 1651733 Status: Offline Thanks Meter: 21 | lumnia 520 Dead after Flash Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== IMEI: 358352056399259 Version: 1.1.1.3 Product Code: 059S1T3 Module Code: 0205435 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010C011700 UEFI App: FLASH APP Flash App Protocol Version: 1.12 Flash App Implementation Version: 1.23 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: LAST DATA BLOCK REJECTED! Check your Flash File and Phone Connection ERROR: Flashing Failed! |
05-01-2014, 11:49 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Phone could be dead if (flash file used are for other rm-xxx / USB communication problem) Error on last data block shouldn't make phone dead, check with other fully charged battery. It might be in Recovery mode / Red Nokia logo. If not, then you need to repair phone's boot with ATF. I and many other users daily flashing lumia phone with ATF, and not a single phone was dead on flashing with me. So the problem must be from your side and not ATF software. Check/Change USB Port or USB cable first Double check your flash files, they are for correct rm-xxx as your phone you flashing Sometime flash files are not fully downloaded. So download files once again to make sure if they are not corrupted. |
05-01-2014, 13:19 | #4 (permalink) |
Crazy Poster Join Date: Nov 2011
Member: 1682468 Status: Offline Thanks Meter: 6 | thank you for his response, but after flashing and have error at the end of the (failed) I now have a new problem nokia lumnia could not conect from usb lumnia 520 Dead after flash (no response at ATF nitro) lumnia 520 if I experience dead boot ...? whether the need is there jtag jtag and her ..? or jtag no other way than to be able to conect via USB or needs to repair the boot ...? please solution for this thank U br david delta |
05-01-2014, 14:40 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | You can repair boot via eMMC if you do not want to pay for JTAG activation. ATF supports boot repair via eMMC since more than 1 year already. Last block error does not result in dead phone. Phone will only die if: 1. Your flash file is corrupted 2. Flashing failed before 5% progress is reached 3. Battery became empty during flashing... and it is an internal battery. Dead Lumia does not charge battery at all. B.R. |
