03-13-2014, 16:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Make Easy Unlocking Life, Unlocked With ATF 4 IN 1 Ultimate JTAG/EMMC/ISP/MMC Adaptor Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 21568545 ACTIVE Level 1 PUK: 10460797 ACTIVE Level 2 PIN: 41480794 Level 2 PUK: 89242938 Level 3 PIN: 39590731 Level 3 PUK: 83493498 Level 4 PIN: 10929577 Level 4 PUK: 90861570 Level 5 PIN: 35839496 Level 5 PUK: 65263953 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== |
The Following 4 Users Say Thank You to razib143 For This Useful Post: |
03-20-2014, 05:40 | #3 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
Buy From Here : ATF 4 IN 1 (JTAG-EMMC-ISP-MMC CARD Adaptor) this ATF 4 in 1 Adapter made by us . Before Checkout . you must read the terms of Shipping Policy | |
03-20-2014, 06:39 | #6 (permalink) |
No Life Poster Join Date: May 2004 Location: Peru Age: 54
Member: 67240 Status: Offline Thanks Meter: 45 | Please friend, I am searching your site but I can not find wire that conect ADAPTER to PHONE. See pic.Nokia_610_text.jpg |
03-20-2014, 06:42 | #7 (permalink) | |
Which you Mark In Picture . That Comes with Package ... All Required things in side the package | |
06-02-2014, 14:50 | #9 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Default language ID 0x0409 JTAG Interface Connected, S/N 0xD4034978 Resetting and Exploring JTAG chain...No Devices found in Chain! JTAG Interface Disconnected! JTAG Interface Connected, S/N 0xD4034978 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 76234394 ACTIVE Level 1 PUK: 22253117 ACTIVE Level 2 PIN: 16607267 Level 2 PUK: 54275518 Level 3 PIN: 55593275 Level 3 PUK: 15424283 Level 4 PIN: 47319930 Level 4 PUK: 15246758 Level 5 PIN: 96419133 Level 5 PUK: 92837032 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== |
06-02-2014, 15:03 | #10 (permalink) |
06-14-2014, 17:53 | #12 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia 900 unlock code read done again Default language ID 0x0409 JTAG Interface Connected, S/N 0xD4034978 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 3, compiled 9/23/2013 7:35:00 PM ================================================== ======== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB Sending Flash Loader...OK (72527 Op/Sec) Retrieving Unlock Codes...OKFlash Read Error at 0x06338000, Checksum Error in Loader Answer Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB Sending Flash Loader...OK (72569 Op/Sec) Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 98565313 ACTIVE Level 1 PUK: 25643352 ACTIVE Level 2 PIN: 59570018 Level 2 PUK: 71358398 Level 3 PIN: 82178403 Level 3 PUK: 55900477 Level 4 PIN: 86486250 Level 4 PUK: 55348066 Level 5 PIN: 72156582 Level 5 PUK: 60844524 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears This is PERMANENT UNLOCK... Flashing will NOT RE-LOCK PHONE ================================================== ========================== |
The Following User Says Thank You to razib143 For This Useful Post: |
06-23-2014, 17:59 | #14 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia Lumia 510 Gain Unlock code read done Default language ID 0x0409 JTAG Interface Connected, S/N Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 02809167 ACTIVE Level 1 PUK: 94512015 ACTIVE Level 2 PIN: 86822326 Level 2 PUK: 94462391 Level 3 PIN: 51639018 ACTIVE Level 3 PUK: 21135761 ACTIVE Level 4 PIN: 89359179 Level 4 PUK: 32601166 Level 5 PIN: 21405119 Level 5 PUK: 94707096 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== |
06-24-2014, 15:55 | #15 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia Lumia 610 again read code Done Default language ID 0x0409 JTAG Interface Connected, S/N 0xDxxxxxxxxx Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 20264775 ACTIVE Level 1 PUK: 85471389 ACTIVE Level 2 PIN: 94142253 Level 2 PUK: 07799257 Level 3 PIN: 00422194 Level 3 PUK: 58169310 Level 4 PIN: 31531433 Level 4 PUK: 71500532 Level 5 PIN: 32633808 Level 5 PUK: 32056138 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== |
