05-18-2020, 15:45 | #121 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Philippines, iloilo city
Member: 1453900 Status: Offline Thanks Meter: 74 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.50 AdvanceBox SN : 9F363F62EA2E3D70E20xxxx ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-20-2020, 21:06 | #122 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Transylvania
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : A4987FF4D5959C1BFAxxxxxx ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software |
05-23-2020, 12:11 | #123 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Tanzania -Shy-Town
Member: 1979644 Status: Offline Sonork: mk47 Thanks Meter: 26 | offline instiler hi we thank for your support but it is a time to release offline instiller were tired of this error. Please Try Again Later (Server Busy) Thanks |
05-23-2020, 17:04 | #124 (permalink) |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | atf server is dead? ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-27-2020, 18:20 | #125 (permalink) |
Junior Member Join Date: Jan 2009
Member: 938179 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.30 AdvanceBox SN : 9BA1E82CC141DFF2DD98181C ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-29-2020, 06:30 | #126 (permalink) |
Insane Poster Join Date: Nov 2017 Location: uzbekistan
Member: 2782328 Status: Offline Thanks Meter: 6 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 15B32DEACB37D114D65BA6F4 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ANY SOLUTION???? PLEASE???? run server please |
05-29-2020, 15:29 | #127 (permalink) |
Member: 938179 Status: Offline Thanks Meter: 0 | Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 9BA1E82CC141DFF2DD98181C ========================================= |
05-29-2020, 15:44 | #128 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | Server is working fine actually - FEB, 2020 FALSE!!!!!! sever down dead Product BR, -=MR_Gsm |
The Following 3 Users Say Thank You to -=MR_Gsm=- For This Useful Post: |
06-06-2020, 03:06 | #130 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 189487 Status: Offline Thanks Meter: 30 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : D716FAECAE2A61B288678008 |
06-06-2020, 08:05 | #131 (permalink) |
Junior Member Join Date: Jul 2009 Location: VietNam
Member: 1071520 Status: Offline Thanks Meter: 0 | Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : D751FF3DF9B42B9DF41165B7 |
06-06-2020, 15:44 | #132 (permalink) |
Junior Member Join Date: May 2020 Location: Palestine
Member: 2958372 Status: Offline Sonork: 645687 Thanks Meter: 0 | Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : E81F9E20B3104A5586918205 ========================================= Please Try Again Later (Server Busy) ========================================= |
06-13-2020, 13:35 | #133 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1666850 Status: Offline Thanks Meter: 0 | atf server problume plz fix Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 96CBC2EFCD36C9AFC029E282 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
06-16-2020, 05:23 | #134 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2864035 Status: Offline Thanks Meter: 0 | Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : BBF97D5AB90CF261D33DE11D ========================================= Please Try Again Later (Server Busy) ========================================= |
06-16-2020, 05:40 | #135 (permalink) |
Insane Poster Join Date: Sep 2007 Location: PAKISTAN MULTAN MUZAFAR GHARH
Member: 580309 Status: Offline Sonork: NO HAVE Thanks Meter: 21 | Advance Turbo Flasher Found ================================================ Driver Version : 00021228 Library Version : 00030214 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : BC6EC0329CD2F93BCA442B18 ========================================= Please Try Again Later (Server Busy) |
