March 05, 2017: Info regarding ATF Activation Server: Hi, ATF Server is in Maintenance. Problems with ATF Activation will be resolved in next few days. If you get this error while Activating New Box or if you just formatted PC: "Please Try Again Later (Server Busy)" This means you have to wait a few more days until server will be up and running again. Hope to see no more of these type post in the section after my this Thread... BR |
Thanks Angel bro for inform us.I hope my ATF again rock as past new models come in Nokia and we need Team ATF. |
hi, there can be a full update to invest 12.67 support! Thanks.... |
atf network is the atf network is working......showing invalid responce |
ATF team are looking forward to be able to fulfill its maintenance. all our work is halted |
================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020422 Library Version : 00030119 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : C0A153F4C9039481F38988E7 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : FA546C219E4BC486C9C0D2D2 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
Yes after u fix server froblem the user need to fix nokia mtk flashing froblem becose its our neded now thanks |
Thanks sir for information ATF Server Error |
Waiting for a new product !!! |
atf box server busy problm kb thk ho gi jnb |
Today's March 05, 2017 when ATF support server will comeback? |
Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : D58CF75A81141888F18DB654 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ |
