03-05-2017, 11:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | March 05, 2017: Info regarding ATF Activation Server: ATF Server is in Maintenance. Problems with ATF Activation will be resolved in next few days. If you get this error while Activating New Box or if you just formatted PC: "Please Try Again Later (Server Busy)" This means you have to wait a few more days until server will be up and running again. Hope to see no more of these type post in the section after my this Thread... BR |
The Following 39 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-05-2017, 11:51 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Thanks Angel bro for inform us.I hope my ATF again rock as past new models come in Nokia and we need Team ATF. |
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
03-05-2017, 15:38 | #6 (permalink) |
Junior Member Join Date: May 2014
Member: 2192502 Status: Offline Thanks Meter: 1 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020422 Library Version : 00030119 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : C0A153F4C9039481F38988E7 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following User Says Thank You to zakria higazy For This Useful Post: |
03-05-2017, 16:01 | #7 (permalink) |
Junior Member Join Date: Jan 2009
Member: 955969 Status: Offline Thanks Meter: 1 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : FA546C219E4BC486C9C0D2D2 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-05-2017, 17:44 | #8 (permalink) |
No Life Poster Join Date: Jan 2016 Location: Gsm flashing
Member: 2521913 Status: Offline Thanks Meter: 251 | Yes after u fix server froblem the user need to fix nokia mtk flashing froblem becose its our neded now thanks |
The Following User Says Thank You to Alameeen For This Useful Post: |
03-06-2017, 09:43 | #12 (permalink) | |
Junior Member Join Date: Jul 2013
Member: 1985027 Status: Offline Thanks Meter: 2 | Quote:
The Following 2 Users Say Thank You to jngobz For This Useful Post: |
03-06-2017, 12:25 | #14 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: Live pakistan Age: 46
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | Quote:
The Following User Says Thank You to umardarz For This Useful Post: |
03-06-2017, 12:26 | #15 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1706213 Status: Offline Thanks Meter: 213 | Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : D58CF75A81141888F18DB654 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ |
The Following 3 Users Say Thank You to shahidjanu For This Useful Post: |
