03-11-2017, 16:20 | #61 (permalink) |
Junior Member Join Date: Nov 2014 Location: Miami
Member: 2300329 Status: Offline Thanks Meter: 8 | go to c:\windows\system32\drivers\etc open file "hosts" with text editor remove these 2 entries atf server 174.120.45.28 174.120.45.29 |
The Following 7 Users Say Thank You to labgsm For This Useful Post: |
03-11-2017, 17:08 | #62 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Moskow
Member: 2691652 Status: Offline Thanks Meter: 60 | Thank you brother. It worked. Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : E56982019190839821389979 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-12-2017, 14:07 | #69 (permalink) | |
Junior Member Join Date: Jul 2011 Location: Ukraine
Member: 1613151 Status: Offline Thanks Meter: 0 | Quote:
Updating... Please wait Error downloading URL 174.120.45.27 | |
03-14-2017, 11:23 | #71 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2695288 Status: Offline Thanks Meter: 0 | Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.60 AdvanceBox SN : B39FCC25F3DCE8EACA518356 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ |
03-14-2017, 11:50 | #72 (permalink) |
Insane Poster Join Date: Jul 2014 Location: atlantic ocean
Member: 2225865 Status: Offline Thanks Meter: 38 | BOX not Activating , Due to Error ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== ERROR: Failed to Initialize SDC Module |
03-14-2017, 17:47 | #73 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Đà Nẵng - Việ Age: 44
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | Quote:
