08-06-2013, 08:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | memorycard bruteforce error pls help??? logs: 15:05:31 : 15:05:31 : Resume File Found: 15:05:31 : C:\AdvanceBox Turbo Flasher\sd_card\resume\1B534D303030303010065E6E940 0B2F7.resume 15:05:36 : Warning: Card did not Respond... (0x03) 15:05:36 : Resynching with Card... 15:05:55 : Card Reset Done! 15:05:55 : Initializing Micro SD Card... 15:05:55 : Card Initialized OK (V2.0 Compliant) 15:05:55 : Waiting for IDLE State... 15:05:56 : Card is now IDLE! 15:05:56 : 15:05:56 : Reading Micro SD Card Information... 15:05:56 : Manufacturer ID : 0x1B 15:05:56 : Application ID : SM 15:05:56 : Product Name : 00000 15:05:56 : Product Revision : 1.0 15:05:56 : Serial Number : 065E6E94 15:05:56 : Manufacture Date: February 2011 15:05:56 : 15:05:56 : Card CID: 1B534D303030303010065E6E9400B2F7 15:05:56 : Card CSD: 007FFF325B5A83BAF6DBDFFF0E8000B5 15:05:57 : Card SCR: FFFFFFFFFFFFFFFF 15:05:57 : Card OCR: 0080FF8000 15:05:57 : 15:05:57 : Maximum Speed: 25000000 Hertz 15:05:57 : 15:05:57 : Checking Lock Status... 15:05:57 : Micro SD Card is Password Protected!!! 15:05:58 : 15:05:58 : Resume File Found: 15:05:58 : C:\AdvanceBox Turbo Flasher\sd_card\resume\1B534D303030303010065E6E940 0B2F7.resume 15:06:03 : Warning: Card did not Respond... (0x03) 15:06:03 : Resynching with Card... 15:06:18 : ERROR: Failed to Reset Micro SD Card... |
08-06-2013, 09:05 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Practically i have face that some physically damaged card also ask for password . May be you have same problem Br - srinibas |
08-06-2013, 12:20 | #4 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Russia. city Khasavyurt Age: 42
Member: 128322 Status: Offline Thanks Meter: 13 | No. .. this is not a defect of flash cards .. customer brought me a flash drive card ATF threw an error .. .. I thought that the flash drive spoiled .. today came another client and his memory stick does not work .. Then I took a new USB flash drive put the password and checked again .. and unfortunately the same thing: (.... this is the problem version V10.00 |
08-06-2013, 15:58 | #6 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
08-17-2013, 12:55 | #9 (permalink) | |
Member: 128322 Status: Offline Thanks Meter: 13 | That's what I said a support .. so who urgently need to downgrade. Quote:
