06-29-2016, 10:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | Motorola repair problem Motorola XT1063 was full working and killed by wrong update Code: 12:09:23 : ====================================================== 12:09:23 : ====================================================== 12:09:23 : eMMC Test Point Connection Module 12:09:23 : ====================================================== 12:09:23 : ====================================================== 12:09:23 : 12:09:23 : 1. DO NOT USE THE PHONE"S BATTERY 12:09:23 : 2. Connect the Soldered TP Connections to ATF Box 12:09:23 : 3. Disconnect the USB Cable and Wait until the 12:09:23 : the ATF Software will tell you to Connect the USB. 12:09:23 : 12:09:23 : 12:09:23 : Interface Reset OK! 12:09:23 : eMMC Access Type: SECTOR MODE 12:09:23 : eMMC Supported Voltage Range: 12:09:23 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 12:09:23 : 12:09:23 : CID : 45010053454D3038470743AFE1B0510F 12:09:23 : CSD : D00F00320F5903FFFFFFFFFF8A40407F 12:09:23 : 12:09:23 : eMMC Boot Information 12:09:23 : Revision 1.6 (for MMC v4.5, v4.51) 12:09:23 : BOOT PARTITION : USER AREA 12:09:23 : PARTITION ACCESS : R/W USER PARTITION 12:09:23 : PERM_BOOT_CFG_PROT : DISABLED 12:09:23 : PWR_BOOT_CFG_PROT : DISABLED 12:09:23 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 12:09:23 : RESET BUS WIDTH : ENABLED 12:09:23 : eMMC FirmW UPDATE : DISABLED 12:09:23 : EMMC CACHE SIZE : 0 KB 12:09:23 : SUPER PAGE SIZE : 4096 KB 12:09:23 : HC ERASE GROUP SIZE: 512 KB 12:09:23 : USER AREA SIZE : 7818182656 BYTES 12:09:23 : BOOT PARTITION SIZE: 2048 KB 12:09:23 : RPMB PARTITION SIZE: 2048 KB 12:09:23 : 12:09:23 : 12:09:23 : eMMC Device Information 12:09:23 : Manufacturer ID: SANDISK 12:09:23 : Device Type : Embedded BGA 12:09:23 : Application ID : 00 12:09:23 : Product Name : SEM08G 12:09:23 : Product Rev : 0.7 12:09:23 : Product SN : 43AFE1B0 12:09:23 : Manufactured : January 1998 12:09:23 : 12:09:23 : Card Specific Data 12:09:23 : CSD_STRUCTURE : Extended 12:09:23 : SPEC_VERS : Version 4.1/4.2/4.3 12:09:23 : TAAC : 3 ns 12:09:23 : TRAN_SPEED : 4000000 KHz 12:09:23 : READ_BL_LEN : 512 Bytes 12:09:23 : C_SIZE : HIGH CAPACITY 12:09:23 : WP_GRP_ENABLE : YES 12:09:23 : WRITE_BL_LEN : 512 Bytes 12:09:23 : CONTENT_PROT_APP : NO 12:09:23 : PERM_WRITE_PROTECT: NO 12:09:23 : TMP_WRITE_PROTECT : NO 12:09:23 : 12:09:23 : Extended CSD Saved: 12:09:23 : 45010053454D3038470743AFE1B0510F.ext_csd 12:09:23 : Backup Directory: 12:09:23 : D:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 12:09:23 : flash EMMC_ROM1_00000000_20000000.bin as UserArea (536Mb) flash EMMC_ROM2_00000000_00400000.bin as Boot1 (4Mb) flash EMMC_ROM3_00000000_00400000.bin as Boot2 (4Mb) and try write ext_csd files from backup and from my backup but phone still detects as HS-USB QDLoader 9008 Did i flash these files correctly? Do i need flash ext_csd before or after boot? Thanx [/code] [/code] |
