06-29-2013, 07:42 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: PARADISE ON EARTH(KASHMIR)
Member: 1754881 Status: Offline Sonork: 100.1644926 Thanks Meter: 146 | Mr Angel Sir need your kind attention..............pleaze Thanks in advance |
06-29-2013, 08:16 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | direct flash with 51.9 if not luck then do step by step read rpl read full dump erase phone flash ur desire firmware with same product code write rpl do sl3 recovery from dump write dump pm repair sd write sx4 pm 1 . 309 all done |
06-29-2013, 08:34 | #4 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: Paradise on Earth
Member: 1281866 Status: Offline Thanks Meter: 330 | Quote:
(if you have activate your box you can do given steps other wise buy rpl file | |
06-29-2013, 08:47 | #5 (permalink) |
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | u can backup rpl even in dead mode with full dump mean full flash u can recover ur sl data mean full pm with 308 |
06-29-2013, 10:56 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Mirtelecom Solution is: 1. Authorize Phone via ATF Network 2. Recover Simlock from IMEI and Locks->Simlock->SL3 Recovery->Level 2 from Phone 2a.Once simlock are recovered successfully, you can erase flash and RPL is auto backup already during Authorize Phone 4. Full Erase now 5. Flash with correct RM-XXX and Product Code files 6. Write RPL and Recovered Simlocks 7. Using StandAlone SX4 Authorization - Write PM 1, 309 That's all, phone should be repaired now! BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
06-30-2013, 02:40 | #9 (permalink) | |
Member: 1754881 Status: Offline Sonork: 100.1644926 Thanks Meter: 146 | Quote:
Thanks | |
