Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-27-2012, 10:31   #1 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 115
Multiple ATF Boxes Detected
i followed those steps:
-Deleted atf drivers
-Uninstalled atf
-Removed atf folder
-Installed atf 9.20 full
-Installed signed drivers 2.8.24
-Box firmware restored
-Box Firmware updated
but still not solved
8.90 IS WORKING:
           Advance Turbo Flasher Found
Driver Version       : 00020824
Library Version      : 00030207
Box Type               : ATF Lightning
Box Firmware        : LogiCore 10.3.12
Software Version  : v8.90
AdvanceBox SN    : XXXXXXXXXXXXXXXX
Box Status            : ACTIVATED
          Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 11-27-2012, 10:45   #2 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 115
solved in this way:
1) installed 8.90
2) restored box firmware with atf 8.90
3) installed 9.20
4) updated box firmware with 9.20
Do not restore box with version different then 8.90
Box Firmware        : LogiCore 10.3.30
Software Version  : v9.20
AdvanceBox SN    : xxxxxxxxxx
SET BSI Load Done
Old 11-27-2012, 11:07   #3 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 115
but after some restarts 9.20 again "multiple atf box detected".......
i clicked update firmware, it say "you have last firmware" and then box recognized...
If i restore firmware with 9.10, 9.20 etc, it will never say "you have last firmware", even after firmware updated
Old 10-30-2013, 12:15   #4 (permalink)
Member: 2018552
Sonork: 100.1646408
Thanks Meter: 8
Hello Guys I was worked continuously 15 hours and i think i have tried every on my box For the PROB-- Multiple ATF Box Detected..( I was updating my atf box firmware then suddenly everything shown not responding after 5 minutes i'll remove my box and end all not responding application--- This is my reason for this Problem )
I'll tried Mprog, Restore Box, Update Firmware, Eeprom, Remove & Reinstall Application & Driver, Install New win8.... but nothing worked.. Remember Blue light continuously on of my box when i suffering with this problem.
100% tested working on my box solution --
1- Remove old application & Driver then Reinstall latest application & Driver.
2- Try to Activate the Box.
3- Restore Box.
4- Update Firmware.
5- Close application Remove Box & plug in again & open your application.
I think your box is OK after this... THanks.
( I'll search every where on net but no any other soltion for this in upto October 13 )
* - Download - 4shared - Shubham Soni
Old 10-30-2013, 12:45   #5 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
-Uninstalled atf
-Removed atf folder
8.90 IS WORKING:
SET BSI Load Done
bro only driver problem uninstall and install latest version 10.30
Page generated in 0.16947 seconds with 8 queries
