09-22-2012, 09:50 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | Multiple ATF Boxes Detected ???? <<< SOLVED - SOLUTION INSIDE >>> |
09-22-2012, 10:03 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, 1. Disconnect ANY other device connected with PC 2. Open: "c:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\MProg.exe" 3. Scan for available devices by press CRTL+C 4. Open Existing Programming Template by press CRTL+O 5. Select "new abox turboflasher.ept" 6. Erase All Exisiting Devices by press CRTL+E 7. Program All Existing Devices by press CRTL+P 8. Re-connect ATF Box from USB cable 9. Install ATF Box Drivers from here: "c:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS" BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
09-22-2012, 10:24 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Quote:
Am I sure to do this ? Sometime working sometime this error. ................. | |
09-28-2012, 14:54 | #13 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 393902 Status: Offline Thanks Meter: 4 | I have the same problem. 1. mprog procedure 2. when open ATF then show me MULTIPLE ATF 3. I tried update firmware - query result - not found What can I do because I need stuff to work |
09-28-2012, 15:13 | #15 (permalink) |
Member: 393902 Status: Offline Thanks Meter: 4 | Succesfull done. The rest step of your procedure will be: 10. Disconnect ATF box and run ATF software (No ATF box found) 11. Connect ATF box and go to tab Product Support -> Box Tools and click Restore Box and choose ATF big (normal or modified) or lightning 12. After restore finished then click Update firmware. Done |
The Following User Says Thank You to Tommi_GSM For This Useful Post: |
