03-11-2013, 11:36 | #3 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Probelam solve now Hello Guys, Old PCB <-- This PCB can be modified New PCB <-- This PCB CANNOT BE MODIFIED BECAUSE IT DOES NOT NEED TO BE MODIFIED... The Problem with the New PCB is when you accidentally put "modified box" firmware to it. Since Firmware inside the Box will be WRONG,, that is why it cannot power ON Phones anymore and you will just see "BLUE" and "ORANGE" lights all the time. The solution is simple... (Take note this is for BIG ATF BOX with NEW PCB written PCB v1.3) 1. Download this: http://174.120.45.27/tmp/NEW_PCB_81510.rar 2. Disconnect ALL BOXES from USB Port (DISCONNECT ATF BOX AS WELL) 3. Close ATF Software 4. Connect ATF Box to USB Port 5. Extract "NEW_PCB_81510.rar" and inside you will find "new_pcb.bat" 6. Run "new_pcb.bat" and wait for 3 minutes or until it will finish without errors. *** Take note that all LEDs should be ON during firmware is updating *** After All work uninstall ver then reinstall probelam solve And also using MProng 3.5 Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.50 Software Version : v9.61 AdvanceBox SN : FAFD821F8DE0-------------- Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following 3 Users Say Thank You to azhergoga007 For This Useful Post: |
03-11-2013, 15:59 | #5 (permalink) | |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Quote:
[email protected] | |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
03-13-2013, 13:22 | #11 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Angel Sir where r u i neead ur Help plz My ATF Box Fbus Port Not Workin But Usb Flash Working I am Wating For Ur Responce plz plz plz Plz |
03-13-2013, 21:25 | #12 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Go to Product Support tab->Box Tools->Tick Normal PCB And click on "Restore Box" button. After it is completed... Try to connect any phone and check. BR | |
