02-18-2011, 11:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: RSA/HONG KONG/SHENZHEN/BNGKOK Age: 41
Member: 225128 Status: Offline Sonork: 1602598 Thanks Meter: 25 | my atf box keep saying update firmware ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ****************************************** INIT : FAILED , CHECK YOUR BOX FIRMWARE ****************************************** |
02-19-2011, 02:44 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @hicmet When you connect ATF Lightning to USB port, do you see a pop up message on the Lower Right corner of your Windows Desktop telling you: "This Device Can work faster if connected to a USB 2.0 Port... For A list of USB 2.0 Ports, click here..." ? I think it does... B/R |
02-19-2011, 11:35 | #9 (permalink) | |
Member: 225128 Status: Offline Sonork: 1602598 Thanks Meter: 25 | Quote:
02-22-2011, 10:01 | #11 (permalink) |
Member: 225128 Status: Offline Sonork: 1602598 Thanks Meter: 25 | i got box to work now without giving usb 2.0 problem,when i open box it shows the following:AdvanceBox Turbo Flasher Found Driver Version : 00020601 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : ATF Lightning Box Firmware : LogiCore 9.02.10 Software Version : v6.60 AdvanceBox SN : E30209B8D973E065E1BC84A4 BOX Status : NOT ACTIVATED INIT : OK VBATT OFF... VBATT ON Setting VBATT Done!... my box is activated and my firware is up to date.... if i try to bus check a phone i get the following error...VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed |
02-22-2011, 14:55 | #12 (permalink) |
Member: 225128 Status: Offline Sonork: 1602598 Thanks Meter: 25 | when i open atf it says box not activated but my box is activated,my firware is also up to date,i disabled anti virus and firewall but keep giving me error and freezes,i got atf box more than a week now and im just not coming rite |
02-22-2011, 15:56 | #13 (permalink) | |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | Quote:
Contact me in sonork www.sonork.com download and install. I can teamviewer you. I tell you second time already BR Thomas | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
