my atf box keep saying update firmware i update everytime but it still keep saying update firmware when i open prog.INIT : FAILED , CHECK YOUR BOX FIRMWARE.========================================= ===== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ****************************************** INIT : FAILED , CHECK YOUR BOX FIRMWARE ****************************************** |
it downloads but then after that still say please click update firmware |
Hello, Change USB cable and re-install drivers.. BR |
im using atf lightning,no usb cable |
check PC USB port are 2.0.Connect directly to PC port. use latest ftdi driver for ATF |
will try 2mro,im running it on vista |
its windows proplem.. you should fomat and setup windows |
@hicmet When you connect ATF Lightning to USB port, do you see a pop up message on the Lower Right corner of your Windows Desktop telling you: "This Device Can work faster if connected to a USB 2.0 Port... For A list of USB 2.0 Ports, click here..." ? I think it does... B/R |
any1...... must be a solution<<<<<< guys that are using atf light on win vista and win 7 |
i got box to work now without giving usb 2.0 problem,when i open box it shows the following:AdvanceBox Turbo Flasher Found Driver Version : 00020601 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : ATF Lightning Box Firmware : LogiCore 9.02.10 Software Version : v6.60 AdvanceBox SN : E30209B8D973E065E1BC84A4 BOX Status : NOT ACTIVATED INIT : OK VBATT OFF... VBATT ON Setting VBATT Done!... my box is activated and my firware is up to date.... if i try to bus check a phone i get the following error...VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed |
when i open atf it says box not activated but my box is activated,my firware is also up to date,i disabled anti virus and firewall but keep giving me error and freezes,i got atf box more than a week now and im just not coming rite |
Contact me in sonork :) www.sonork.com download and install. I can teamviewer you. I tell you second time already :) BR Thomas |
problem sole 1000000000000000% problem sole 1000000000000000% |
i also have same problem. can anyone help me please |
