Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-18-2011, 11:14   #1 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
Question my atf box keep saying update firmware
i update everytime but it still keep saying update firmware when i open prog.INIT : FAILED , CHECK YOUR BOX FIRMWARE.========================================= =====
ATF Box is not in USB 2.0 Mode
* Go to "Product Support" tab and click the
* "Restore Box" Button to fix the Box Firmware
** If Problem is Not Solved...
1. Make Sure you are NOT using USB HUBS
2. Make Sure your USB port is USB 2.0
3. Make Sure you are using the latest Drivers
*** If Problem is STILL Not Solved
1. Use a THICKER USB Cable
2. Connect ATF Directly to the Root USB Port
3. Uninstall Drivers, Reboot PC, Reinstall
**** If you are still Stuck...
1. Search your entire PC for "ftdibus.sys
2. Delete all "ftdibus.sys" files you find
3. Reboot PC...
4. Disconnect ATF Box and all Boxes from PC
5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. ReInstall ATF Software
7. Connect ATF Box Only to your USB Port
8. Install the Correct Drivers
Old 02-18-2011, 13:17   #2 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
it downloads but then after that still say please click update firmware
Old 02-18-2011, 14:04   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,469
Hello,
Change USB cable and re-install drivers..
Old 02-18-2011, 14:15   #4 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
im using atf lightning,no usb cable
Old 02-18-2011, 15:58   #5 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 323
check PC USB port are 2.0.Connect directly to PC port. use latest ftdi driver for ATF
Old 02-18-2011, 20:58   #6 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
will try 2mro,im running it on vista
Old 02-18-2011, 23:03   #7 (permalink)
Member: 776526
Sonork: 1590976
Thanks Meter: 7
its windows proplem.. you should fomat and setup windows
Old 02-19-2011, 02:44   #8 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,026
@hicmet
When you connect ATF Lightning to USB port, do you see a pop up message on the
Lower Right corner of your Windows Desktop telling you:
"This Device Can work faster if connected to a USB 2.0 Port...
For A list of USB 2.0 Ports, click here..."
I think it does...
B/R
Old 02-19-2011, 11:35   #9 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
Question
Originally Posted by Advance-Box View Post
@hicmet
I think it does...
B/R
yes my man you are rite it said that a good couple of times when i connected atf,i also get a disconnecting/connecting usb sound... like im plugging it in and out,i think u got the rite picture... what is my proper solution??
Old 02-21-2011, 15:27   #10 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
any1...... must be a solution<<<<<< guys that are using atf light on win vista and win 7
Old 02-22-2011, 10:01   #11 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
i got box to work now without giving usb 2.0 problem,when i open box it shows the following:AdvanceBox Turbo Flasher Found
Driver Version : 00020601
Library Version : 00030119
Initialize Device....
Init TRY : 1
Box Name : ATF Lightning
Box Firmware : LogiCore 9.02.10
Software Version : v6.60
AdvanceBox SN : E30209B8D973E065E1BC84A4
BOX Status : NOT ACTIVATED
INIT : OK
VBATT OFF...
VBATT ON
Setting VBATT Done!...
my box is activated and my firware is up to date.... if i try to bus check a phone i get the following error...VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
VBATT OFF...
VBATT ON
BootFlashModeDCT5Ex Failed
Old 02-22-2011, 14:55   #12 (permalink)
hicmet's Avatar
Member: 225128
Sonork: 1602598
Thanks Meter: 24
when i open atf it says box not activated but my box is activated,my firware is also up to date,i disabled anti virus and firewall but keep giving me error and freezes,i got atf box more than a week now and im just not coming rite
Old 02-22-2011, 15:56   #13 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,572
Hi
Contact me in sonork
www.sonork.com download and install.
I can teamviewer you. I tell you second time already
Thomas
Old 10-13-2012, 13:32   #14 (permalink)
Member: 1815460
problem sole 1000000000000000%
Old 08-08-2014, 16:05   #15 (permalink)
Member: 2207666
Sonork: 100.28977
i also have same problem.
can anyone help me
please
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Page generated in 0.40300 seconds with 8 queries
