06-26-2014, 20:25 | #4 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Remove the driver using driver folder remove driver exe ... Again install the driver & update driver .. Also cake the cable .. Br, AniAXN |
06-30-2014, 09:58 | #8 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | hi, ceck Main cable ceck Pc port USB 2.0 and post what show in "Device Manager" first install last version 11,50, if not show anythingh in "Device Manager" then can be Atf pcb port problem, Br allumts |
06-30-2014, 17:52 | #10 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | hi, in this photo you Atf not result connected to any port, where is you Atf?, only Sw is showing. Ceck you main cable if is connected from Atf to pc directly in motherboard, When connect main cable you Atf have light on, (green light), or no light you see? Post also photo of you Atf Pcb of both sides, Br allumts |
