04-18-2012, 07:58 | #6 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
*** MAKE SURE ONLY ATF BOX IS CONNECTED ON THE USB PORT... *** If you connect other Boxes , then Your other boxes will HAVE *** PROBLEMS 1. Download This File: http://www.ftdichip.com/Drivers/CDM/..._Certified.zip 2. Force Update the drivers for USB Serial Converter A using the Drivers from Step 1. 3. Force Update the drivers for USB Serial Converter B using the Drivers from Step 1. 4. Restart your PC if it asks you to restart... 5. Run MPROG and Write this EEPROM File to your ATF Box: new abox turboflasher.ept *** MAKE SURE ONLY ATF BOX IS CONNECTED ON THE USB PORT... *** If you connect other Boxes when writing the EEPROM, then *** Your other boxes will HAVE PROBLEMS 6. After Writing the EEPROM to your ATF Box, Disconnect The ATF Box from the USB Port, then reconnect it. It will now ask for drivers... 7. Use the correct drivers from: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ Original post - http://forum.gsmhosting.com/vbb/7717008-post4.html Br - srinibas ( ATF Team ) | |
04-18-2012, 12:20 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
If you can see ATF Box Ports in Device Manager like: AdvanceBox Programming Ports AdvanceBox Turbo Flasher And still on SW box not detected, than solution is: 1. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 2. Reconnect Box and Install Drivers from here: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS It will be Ok. If you cannot see ATF Box Ports in Device Manager and just: Universal Serial Converter A Universal Serial Converter B Than solution is: http://forum.gsmhosting.com/vbb/8330894-post6.html BR | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
