Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 09-15-2011, 07:06   #1 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 338
My ATF is not detecting Please Help! - (SOLVED)
My ATF box is not detecting by Software and also now its drivers are changed from Normal ATF drivers to USB Serial Converter A and USB Serial Converter B
although I haven't attached any short circuit I have just removed drivers and reinstalled and removed and reinstalled ATF software but still same now it is not detecting even to other PC when I Connect to my Laptop it is known as
USB Serial Converter A and USB Serial Converter B not as ATF box.
Please help and guide how to solve this problem>
WBR
Old 09-15-2011, 07:13   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,041
DO you have team viewer?
POst details and give me access... I can help you now
Old 09-15-2011, 07:28   #3 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 338
Hi Sir
Here is my Team-viewer ID and Password:
ID: 915 XXX 657
Pass: XXXX
Old 09-15-2011, 07:44   #4 (permalink)
Member: 651945
Originally Posted by NKhan_Gsm View Post
Hi Sir
ID: 915 XXX 657
Pass: XXXX
Your Internet Connection/TeamViewer is very very very VERY slow...
Try to do this:
*** MAKE SURE ONLY ATF BOX IS CONNECTED ON THE USB PORT...
*** If you connect other Boxes , then Your other boxes will HAVE
*** PROBLEMS
1. Download This File:
http://www.ftdichip.com/Drivers/CDM/..._Certified.zip
2. Force Update the drivers for USB Serial Converter A using the Drivers
from Step 1.
3. Force Update the drivers for USB Serial Converter B using the Drivers
from Step 1.
4. Restart your PC if it asks you to restart...
5. Run MPROG and Write this EEPROM File to your ATF Box:
new abox turboflasher.ept
*** If you connect other Boxes when writing the EEPROM, then
*** Your other boxes will HAVE PROBLEMS
6. After Writing the EEPROM to your ATF Box, Disconnect The
ATF Box from the USB Port, then reconnect it. It will now ask for
drivers...
7. Use the correct drivers from:
C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\
If you want me to help you in teamviewer,, please try to prepare a faster
internet connection... I could not even move your mouse...
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-15-2011, 08:10   #5 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 338
Thanks Sir for your help and guiding ,Sir from where I can get ATF Eeprom and Im using MPROG ver 3.0a is it ok and would you please tell me how to write Eeprom to ATF?
WBR
Old 09-15-2011, 08:27   #6 (permalink)
Member: 651945
*** Make sure only ATF Box is connected on the USB Port
*** Other GSM Boxes Connected on the USB port will be damaged
*** Dsiconnect Other GSM Boxes such as UFS etc... first...
1. Run MPROG 3.5
C:\AdvanceBox Turbo Flasher\Driver\MProg 3.5 Release\Mprog.exe
2. Click File --> Open
Select File "new abox turboflasher.ept"
C:\AdvanceBox Turbo Flasher\Driver\new abox turboflasher.ept
3. Click Device --> Erase
4. Click Device --> Program
5. Disconnect ATF Box From USB Port, wait 5 seconds, then reconnect
ATF Box to USB Port...
6. Install ATF Drivers from
Old 09-15-2011, 08:44   #7 (permalink)
Member: 240133
Sonork: 1592086:hama19
Thanks Meter: 6
instal new drever ...............
Old 09-15-2011, 08:54   #8 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 338
Sir Thanks a lot for your help and support problem solved .This is called a real support.
WBR
Old 04-17-2012, 11:43   #9 (permalink)
Member: 324879
Thanks Meter: 75
its work brother,thankyou,now my atf can breath again after 4 month dying
The Following User Says Thank You to waiaw For This Useful Post:
Old 04-05-2013, 14:02   #10 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,403
plz plz plz plz plz plz
where r u copy pasterr
SHIJILFONOTLY
give me tha
solution
SHIJILFONOTLY
Atf Not Connect PC(Solution Here)
Old 04-06-2013, 08:56   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,231
SHIJILFONOTLY
give me tha
solution
SHIJILFONOTLY
1st - write in normal font , no one here blind / eyesight problem
2nd - No relation with SHIJILFONOTLY as official , He is not a PS of ATF
3rd - Post your detail problem , Team here to help you
Br - srinibas
Old 04-06-2013, 10:51   #12 (permalink)
Member: 1771086
Thanks Meter: 2,403
Br - srinibas
1 bro when i do update box some time it gives box error INIT : FAILED * CHECK YOUR BOX FIRMWARE
2 then again try update box Firmware AFTER I TRY TO RESTORE THE THE BOX AT THE END BOX ERROR
3 i search in Google i get 1 trick (e prom update) when i do eprom update
then pc auto restart
now not connected box with pc
Old 04-06-2013, 11:28   #13 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Attach the screenshot of Device manager of your PC with USB expand , when ATF connected
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 02-08-2014, 14:18   #14 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Thanks Meter: 3,258
yesterday it was working.
I use today, and does not recognize this USB Drive Serial Port
Old 02-08-2014, 14:26   #15 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,258
resolved
I uninstalled
Rebooted the PC
And did the installation again
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 11-23-2017 07:11
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.45284 seconds with 8 queries
