05-15-2014, 09:53 | #1 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | My atf not work |
05-19-2014, 09:03 | #3 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | ATF Software Version v11.30 ATF Box FBUS Flash Started... Number of Image Files: 3 ================================================ Basic Phone Information ================================================ WARNING: Simlock Backup Failed If this is a Dead Phone, just click YES to Continue with the Flash Procedure... Changing MODE : FLASH Booting Phone via FBUS... BootFlashModeDCT5Ex Failed Failed to complete RPL backup.. Processing Image File : I:\5130_RM_495\7.97\rm495__07.97.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 1178 Entry Point : 0x5057 Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... BootFlashModeDCT5Ex Failed Operations Failed.... ================================================ Basic Phone Information ================================================ ================================================ Basic Phone Information ================================================ Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED phone is ok and other device read info but atf BB5 port not work plz Help |
05-19-2014, 10:06 | #4 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Other boxxx info sir UFS S/N 1504984 boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 5130c-2 Software ver : V 07.91 29-10-09 RM-495 (c) Nokia IMEI : 351538040942835 XappVer : 00000762 DSP Ver : ICPR72_09w33 PPM : V 07.91 29-10-09 RM-495 (c) Nokia MEN CNT : Content: mena_a_blu CTV MENA A MUSIC V2 29-10-09 RM-495 (c) Nokia Product SN : IRI702720 Product code : 0576625 Base Prd.code: 0567773 Module code : 0204024 Long Prod.SN : 0 Hardware info======= HWID : 2002 Retu : 16 Tahvo : 22 Batery: 4836 mV CMT BT: 2222-302 LCDVer: SEIKO RF ic : 06540601 Lock info =========== IMEI : 351538040942835 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 99887 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... |
05-25-2014, 06:06 | #12 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @azhergoga007 You wake up and check post #2 We asked you a question and you did not answer. http://174.120.45.27/modify_pcb/modify_pcb.rar |
