02-19-2014, 12:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2008
Member: 896307 Status: Offline Sonork: 0096 Thanks Meter: 231 | MY turbo box only accept this ver,v8.70 and refuses to be updated setup and firmware Advance Turbo Flasher Found ================================================ Driver Version : 00020819 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.70 Software Version : v8.70 AdvanceBox SN : 879BBE52AC1931.......... Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= only works on this ver 8.70 |
02-19-2014, 12:34 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
- Close Antivirus and Firewall - Instal the Full Fix V.11 exe - connect Atf and Update FTDI drivers whith the NEW in "device Manager" - go in tab "Product Support" > Box Update fw then "Update Files" - restart pc when Sw is updatate - Update from tab "Product Support", "Ceck New Update" and "Update files" - Restart the sw - Update "Nokia Drivers" and "Winusb x86 or x64" (depend you SO) - Restart the Sw and post result regards allumts | |
03-04-2014, 13:19 | #4 (permalink) | |
Member: 896307 Status: Offline Sonork: 0096 Thanks Meter: 231 | Quote:
thanks | |
03-04-2014, 17:45 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
