06-10-2015, 11:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 5AAB Age: 37
Member: 167191 Status: Offline Thanks Meter: 363 | n7000 not connected with atf emmc always get this error in n7000 sudden dead ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 testpoint already connected well, i am using smartgsm adapter v2 points connected 3.3v,2.8v,data,clk,gnd,cmd all helps apprecited thnx |
The Following User Says Thank You to gurinder For This Useful Post: |
