12-18-2016, 09:06 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | n7100 emmc repair, need help. stuck on writing! need to repair N7100 Emmc. Info Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF11F2D71699FED CSD : D02701320F5903FFF6DBFFFF8E406009 eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.1 Product SN : 1F2D7169 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF11F2D71699FED.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ do i need to write emmc firmware or follow this http://forum.gsmhosting.com/vbb/f609...epair-1785442/ by follow xshadow this post every thing is ok but when writing user area software stuck and ok trying to establish emmc . i wait but software retries 59, and no luck. |
