Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-20-2014, 10:18   #1 (permalink)
F-Buzz's Avatar
Member: 730337
Thanks Meter: 65
N7100 invalid rpmb data
i change replace emmc N7100 with emmc i9500 (V3W00M)
i write boot2 , boot1 dan user area with atf , and i flash with OS 4.1.2 working good
when i upgrade to OS 4.3 or 4.4 , phone is bootloop and i enter downloading mode show INVALID RPMB DATA
what solution for this ?
i was try change boot1 and boot 4mb to 2mb , and xcsd wih 512 kb to 128kb but same condition
Old 12-22-2014, 10:40   #2 (permalink)
F-Buzz's Avatar
Member: 730337
Thanks Meter: 65
hello team
i waiting for solution
Old 12-22-2014, 10:52   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@F-Buzz
It means phone eMMC CHIP was taken from another phone.
Exynos Based phones makes unique KEY based on CPU register for RPMB Read/Write. Once they make the KEY, it is stored inside eMMC and it cannot be read or altered, unless you perform something like a complete eMMC Firmware factory Restore.
I believe one eMMC box will allow you to do this. But it is not yet supported in ATF. If really a lot of people will have this problem, then I can implement it as I already have info from emmc firmware.
Old 12-22-2014, 11:16   #4 (permalink)
F-Buzz's Avatar
Member: 730337
Thanks Meter: 65
@Advance-Box
is this problem with emmc firmware ?
what emmc box supported repair/write emmc frimware ?
couse my 3 of 10 emmc chips invalid rpmb data
can you help me sir
Old 12-22-2014, 19:54   #5 (permalink)
T Mobile's Avatar
Member: 186632
Thanks Meter: 51
hi
i need too, please give here more eMMC firmware info
Old 12-23-2014, 05:49   #6 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 262
Originally Posted by Advance-Box View Post
@F-Buzz
Same problem with my S5. http://forum.gsmhosting.com/vbb/f609...-emmc-1861882/
I tried to work by emmc box making dump full emmc not ok, easyjtag not ok too. Ever took emmc from good alive G900H, try to format, wr, read but got same bad result too.
Old 05-08-2015, 12:23   #7 (permalink)
Member: 1012390
Thanks Meter: 95
Mr Anvance-Box, is there any new about this problem? Can you make ATF repair Invalid RPMB data?
Old 05-08-2015, 13:11   #8 (permalink)
Member: 651945
If eMMC is samsung brand, then you can perform Firmware Update + Format and it will erase RPMB data. It will then allow you to use eMMC on any phone.
Of course, you need to write EXT_CSD and BOOT1, BOOT2 and USER... but I
Am sure you already know this.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 05-08-2015, 19:09   #9 (permalink)
Member: 1012390
Thanks Meter: 95
Thank you, sir
Pls support firmware for this type is: KLMAG4FE4B-B002
I often see this EMMC on Samsung SHV-E210L but this pbc is E210S/K and maybe it was refurbished.
At first the customer give the phone, it stuck at Samsung logo, it get various red lines on recovery. On Download mode, it show Product Name: E210S
Then i connect via EMMC and Samsung factory format, then it show RPMB: INVALID RPMB DATA
Old 05-08-2015, 20:23   #10 (permalink)
toninhosantos's Avatar
Member: 1320000
Sonork: 100.1667898
Thanks Meter: 272
Go product suport/update files/ download important files and try again.
The Following User Says Thank You to toninhosantos For This Useful Post:
Old 05-08-2015, 20:39   #11 (permalink)
Member: 1012390
Thanks Meter: 95
Opp.. supported, also update but my network so very slow, now i open folder and see it there
Old 05-08-2015, 20:56   #12 (permalink)
Member: 1012390
Thanks Meter: 95
Oh, i'm sorry. I just check again on PBC and this type exact is: KLMAG2GEAC-B002
The picture and information above that i google search for information and was wrong.
Lucky that the type that i was wrong was supported by ATF
Old 07-22-2015, 19:10   #13 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
I Also Got Same Problem On N7100
It Was Working Well On 4.1.2
Customer Wants To Upgrade It To Latest Kitkat (4.4.2)
After Flashing With Odin With 4.4.2 Now Restarting On Logo
In Download Mode Showing " invalid rpmb data "
Sir Advance-Box
Is There Any Help Possible For Me?
Thanks Anticipation
Old 07-23-2015, 15:11   #14 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
Sir Advance-Box
Thanks Anticipation
your phone is refurbished from china not a original board
update firmware+formate and use 4.1.2 for alive your phone again
The Following User Says Thank You to chand_gee For This Useful Post:
Old 07-23-2015, 16:17   #15 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
update firmware+format Via Direct EMMC?
Or Some Thing Else?
Page generated in 1.06504 seconds with 8 queries
