Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-05-2014, 11:16   #1 (permalink)
Member: 18028
Thanks Meter: 20
N7100 problem
Hi i just replace emmc and do repair like in the pictures for repair but after all write i cant flash with odin.Error repartition fail or no pit partition.So what can be wrong or i need good Write EXT_CSD Backup File because i have some beckup but dont know from what if original emmc was defect.
b.r
Old 09-05-2014, 12:09   #2 (permalink)
Member: 18028
Thanks Meter: 20
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 15010056545530304D088BB068C3
CSD : D02701320F5903FFF6DBFFFF8E40406D
eMMC Boot Information
Revision 1.6 (for MMC v4.5)
BOOT PARTITION : BOOT PARTITION 1
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3584 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 15634268160 BYTES
BOOT PARTITION SIZE: 2048 KB
RPMB PARTITION SIZE: 128 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : VTU00M
Product Rev : 0.8
Product SN : 8BB068C3
Manufactured : September 1997
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRANS_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
15010056545530304D088BB068C3_C4CEBF61.ext_csd
Backup Directory:
H:\atf\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Page generated in 0.12068 seconds with 8 queries
