Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-19-2012, 07:26   #1 (permalink)
raselcox's Avatar
Member: 782943
Sonork: 100.1601067
N73 phone start up fail problem pls help
Hello dear Box supporters pls help me to kick out this problem.
Basic Phone Information
MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
IMEI Plain : 359568011029132
IMEI Spare : A359568011029130
IMEI SV : 33595680110291381F
Phone Model: Nokia N73
Category : Imaging Phone
Phone Type : RM-133
SX4 Custom Keys Stand Alone Edition
>>> : SX4 Auth Successfull
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-133.pm
Start Uploading PM...
Field : 1 Sub : 0 Byte(s): 114 - Ok
Field : 1 Sub : 2 Byte(s): 98 - Ok
Field : 1 Sub : 4 Byte(s): 110 - Ok
Field : 1 Sub : 6 Byte(s): 98 - Ok
Field : 1 Sub : 8 Byte(s): 110 - Ok
Field : 1 Sub : 13 Byte(s): 98 - Ok
Field : 1 Sub : 16 Byte(s): 98 - Ok
Field : 1 Sub : 18 Byte(s): 98 - Ok
Field : 1 Sub : 20 Byte(s): 98 - Ok
Field : 1 Sub : 22 Byte(s): 16 - Ok
Field : 1 Sub : 23 Byte(s): 4 - Ok
Field : 1 Sub : 24 Byte(s): 84 - Ok
Field : 1 Sub : 25 Byte(s): 4 - Ok
Field : 1 Sub : 26 Byte(s): 110 - Ok
Field : 1 Sub : 28 Byte(s): 98 - Ok
Field : 1 Sub : 29 Byte(s): 6 - Ok
Field : 1 Sub : 31 Byte(s): 98 - Ok
Field : 1 Sub : 33 Byte(s): 36 - Ok
Field : 1 Sub : 34 Byte(s): 80 - Ok
Field : 1 Sub : 44 Byte(s): 182 - Ok
Field : 309 Sub : 0 Byte(s): 4 - Ok
Field : 309 Sub : 1 Byte(s): 2 - Ok
Field : 309 Sub : 2 Byte(s): 12 - Ok
Field : 309 Sub : 4 Byte(s): 12 - Ok
Field : 309 Sub : 5 Byte(s): 12 - Ok
Field : 309 Sub : 7 Byte(s): 12 - Ok
Field : 309 Sub : 8 Byte(s): 12 - Ok
Field : 309 Sub : 17 Byte(s): 12 - Ok
Field : 309 Sub : 22 Byte(s): 12 - Ok
PM Upload Done!...
After write pm problem still same. Tried many time but no luck.
Phone Type : RM-133
STEP 1...
STEP 2...
Phone Super Dongle Keys are not Original
Use "Stand Alone SX4" for this Phone...
Phone Type : RM-133
Extended Phone Information
MCU SW Version : V 05wk47v62 05-12-08 RM-133 (c) Nokia.
RFIC Version : 17211721
DSP Version : scarfe_mc.05wk46v50p2
Camera : 1
APE SW Core Version : V 4.0850.43.0.1 12-12-2008 RM-133
Variant Version : V 4.0850.43.0.1-12 12-12-2008 RM-133
RETU Version : 15
TAHVO Version : 22
APE HW Version : 1
APE ADSP SW Version : 256
Bluetooth ID : 00:1E:3B:6C:61:BF
CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I
Simlock Information
Unable to read SP Data..
Phone Type : RM-133
Camera : 1
APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
AHNE Version : 30
RETU Version : 15
TAHVO Version : 22
APE HW Version : 1
Simlock Information
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL1
SIMLOCK_TEST : PASSED
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
PHONE_MODE : TEST
DCC ID : NOT USED
Old 07-19-2012, 08:10   #2 (permalink)
Member: 1706168
Sonork: 100.1619095
Br write RPL without NPC data from C:\AdvanceBox Turbo Flasher\Nokia\RPL_Wout_NPC\N73_without_NPC_DATA.rp l that's all.
Old 07-19-2012, 08:15   #3 (permalink)
raselcox's Avatar
Member: 782943
Sonork: 100.1601067
already done but problem is same. Now what to do?
Old 07-19-2012, 08:22   #4 (permalink)
Member: 1706168
Sonork: 100.1619095
First backup rpl full erase then flash with highest version and same product code and restore RPL do sx4 repair super dongel if not done wait for supporter's answer.
Old 07-19-2012, 08:58   #5 (permalink)
raselcox's Avatar
Member: 782943
Sonork: 100.1601067
I already tried all trick before posting bro. Hello supporters pls reply here to solved this problem. Thanks in advance
Old 08-16-2012, 11:07   #6 (permalink)
asif khokhar's Avatar
Member: 600691
Important:''Backup BB5 RPL&PM'' Then work
1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl)
2. erase old pm ( go > pm tab > erase )
3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this)
4. Erase pm again (go > pm tab > erase )
5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei)
6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309)
7. erase pm again
8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert)
9. give full factory reset
your phone must come back from security test failed
it is 100% tasted by me.
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 2.96484 seconds with 11 queries
