03-05-2013, 15:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | N8 after downgrade Write CMLA Key - Failed <<< SOLVED >>> Got this N8 for user lock as I did not have the latest firmware I tried to downgrade it by erasing and then reflashing the older firmware I followed the following Steps 1. Backup RPL - IMEI and LOCKS->IMEI->Backup RPL 2. Backup Full PM - PM/PP->Read Full PM and simlock data in IMEI tab 3. Full Erase Phone - Flashing->EraseFlash->Scan->Erase 4. Write Flash with lower version - Flashing->WriteFlash - ENO needed for supported models 5. Write Backup RPL - IMEI and LOCKS->IMEI->Write RPL 6. Authorize Phone - ATF Network->Login to account-> Authorize a BB5 NEW HASH Phone 7. Repair SD and Writing PM Backup - PM/PP->Stand Alone SX4->SX4 PM Authorization->Select PM Backup However I get CMLa keys failed every time I try also tried repairing the keys via ATF network it does says fixed but and not sort out the problem, Now the phone stuck on three dots blinking Code: ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia IMEI Plain : 35739804******* IMEI Spare : A357398047****** IMEI SV : 335739804********F Phone Model: Nokia N8-00 Category : Classic Phone Phone Type : RM-596 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\3573980475*****\SL3_certificate_V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia_357398047******_Not Locked_103005.pm Start Uploading PM... Field : 120 Sub : 0 Byte(s): 944 - Ok Field : 120 Sub : 1 Byte(s): 160 - Ok Field : 120 Sub : 2 Byte(s): 132 - Ok Field : 120 Sub : 3 Byte(s): 112 - Ok Field : 308 Sub : 1 Super Dongle Key Found Field : 308 Sub : 1 Write Super Dongle Key - OK Field : 308 Sub : 1 CMLA Key Found Field : 308 Sub : 1 Write CMLA Key - Failed PM Upload Done!... Br frenzy |
08-11-2014, 16:45 | #5 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2236334 Status: Offline Thanks Meter: 0 | Hi friend I've been reading your post here http://forum.gsmhosting.com/vbb/f609...olved-1624011/ I did a downgrade on a Nokia 603 and I also have the same CMLA keys not found, how did you fix it? I was able to install only 12 version of firmware which is Belle FP1 but If I try to put 11.030.0609 which is Belle Refresh the phone is stuck with the three dots loading. How did you fix it? |
08-11-2014, 19:41 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
