11-14-2017, 18:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | N8000 keep on restarting no recovery mode how to repair this kind of problem with my N8000 flashing with odin didn't fix.. i tried with ATF software only removed WP then flash again with odin using high and low version firmware still no luck, i am sure im missing right procedure. please advise me proper procedure to get this tab back to normal state. thank you. log file Code: 00:04:58 : ====================================================== 00:04:58 : ====================================================== 00:04:58 : eMMC Test Point Connection Module 00:04:58 : ====================================================== 00:04:58 : ====================================================== 00:04:58 : 00:04:58 : 1. Make Sure CLK Test Point is already Soldered 00:04:58 : 2. Make Sure CMD Test Point is already Soldered 00:04:58 : 00:04:58 : 00:04:58 : Interface Reset OK! 00:04:58 : eMMC Access Type: SECTOR MODE 00:04:58 : eMMC Supported Voltage Range: 00:04:58 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 00:04:58 : 00:04:58 : CID : 1501004D414732474107201FA5A58F1F 00:04:58 : CSD : D02701320F5903FFF6DBFFFF8A406063 00:04:58 : 00:04:58 : eMMC Boot Information 00:04:58 : Revision 1.5 (for MMC v4.41) 00:04:58 : BOOT PARTITION : BOOT PARTITION 1 00:04:58 : PARTITION ACCESS : R/W USER PARTITION 00:04:58 : PERM_BOOT_CFG_PROT : DISABLED 00:04:58 : PWR_BOOT_CFG_PROT : DISABLED 00:04:58 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 00:04:58 : RESET BUS WIDTH : ENABLED 00:04:58 : eMMC FirmW UPDATE : DISABLED 00:04:58 : EMMC CACHE SIZE : 0 KB 00:04:58 : SUPER PAGE SIZE : 3584 KB 00:04:58 : HC ERASE GROUP SIZE: 512 KB 00:04:58 : USER AREA SIZE : 15758000128 BYTES 00:04:58 : BOOT PARTITION SIZE: 2048 KB 00:04:58 : RPMB PARTITION SIZE: 128 KB 00:04:58 : 00:04:58 : 00:04:58 : eMMC Device Information 00:04:58 : Manufacturer ID: SAMSUNG 00:04:58 : Device Type : Embedded BGA 00:04:58 : Application ID : 00 00:04:58 : Product Name : MAG2GA 00:04:58 : Product Rev : 0.7 00:04:58 : Product SN : 201FA5A5 00:04:58 : Manufactured : January 2012 00:04:58 : 00:04:58 : Card Specific Data 00:04:58 : CSD_STRUCTURE : Extended 00:04:58 : SPEC_VERS : Version 4.1/4.2/4.3 00:04:58 : TAAC : 13 ns 00:04:58 : TRAN_SPEED : 4000000 KHz 00:04:58 : READ_BL_LEN : 512 Bytes 00:04:58 : C_SIZE : HIGH CAPACITY 00:04:58 : WP_GRP_ENABLE : YES 00:04:58 : WRITE_BL_LEN : 512 Bytes 00:04:58 : CONTENT_PROT_APP : NO 00:04:58 : PERM_WRITE_PROTECT: YES 00:04:58 : TMP_WRITE_PROTECT : NO 00:04:58 : 00:04:58 : Extended CSD Saved: 00:04:58 : 1501004D414732474107201FA5A58F1F.ext_csd 00:04:58 : Backup Directory: 00:04:58 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 00:04:58 : 00:14:01 : ====================================================== 00:14:01 : ====================================================== 00:14:01 : eMMC Test Point Connection Module 00:14:01 : ====================================================== 00:14:01 : ====================================================== 00:14:01 : 00:14:01 : 1. Make Sure CLK Test Point is already Soldered 00:14:01 : 2. Make Sure CMD Test Point is already Soldered 00:14:01 : 00:14:01 : 00:14:01 : Interface Reset OK! 00:14:01 : eMMC Access Type: SECTOR MODE 00:14:01 : eMMC Supported Voltage Range: 00:14:01 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 00:14:01 : 00:14:01 : CID : 1501004D414732474107201FA5A58F1F 00:14:01 : CSD : D02701320F5903FFF6DBFFFF8A406063 00:14:01 : 00:14:01 : eMMC Boot Information 00:14:01 : Revision 1.5 (for MMC v4.41) 00:14:01 : BOOT PARTITION : BOOT PARTITION 1 00:14:01 : PARTITION ACCESS : R/W USER PARTITION 00:14:01 : PERM_BOOT_CFG_PROT : DISABLED 00:14:01 : PWR_BOOT_CFG_PROT : DISABLED 00:14:01 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 00:14:01 : RESET BUS WIDTH : ENABLED 00:14:01 : eMMC FirmW UPDATE : DISABLED 00:14:01 : EMMC CACHE SIZE : 0 KB 00:14:01 : SUPER PAGE SIZE : 3584 KB 00:14:01 : HC ERASE GROUP SIZE: 512 KB 00:14:01 : USER AREA SIZE : 15758000128 BYTES 00:14:01 : BOOT PARTITION SIZE: 2048 KB 00:14:01 : RPMB PARTITION SIZE: 128 KB 00:14:01 : 00:14:01 : 00:14:01 : eMMC Device Information 00:14:01 : Manufacturer ID: SAMSUNG 00:14:01 : Device Type : Embedded BGA 00:14:01 : Application ID : 00 00:14:01 : Product Name : MAG2GA 00:14:01 : Product Rev : 0.7 00:14:01 : Product SN : 201FA5A5 00:14:01 : Manufactured : January 2012 00:14:01 : 00:14:01 : Card Specific Data 00:14:01 : CSD_STRUCTURE : Extended 00:14:01 : SPEC_VERS : Version 4.1/4.2/4.3 00:14:01 : TAAC : 13 ns 00:14:01 : TRAN_SPEED : 4000000 KHz 00:14:01 : READ_BL_LEN : 512 Bytes 00:14:01 : C_SIZE : HIGH CAPACITY 00:14:01 : WP_GRP_ENABLE : YES 00:14:01 : WRITE_BL_LEN : 512 Bytes 00:14:01 : CONTENT_PROT_APP : NO 00:14:01 : PERM_WRITE_PROTECT: YES 00:14:01 : TMP_WRITE_PROTECT : NO 00:14:01 : 00:14:01 : Extended CSD Saved: 00:14:01 : 1501004D414732474107201FA5A58F1F.ext_csd 00:14:01 : Backup Directory: 00:14:01 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 00:14:01 : 00:14:01 : 00:14:01 : Task Selected: Samsung Remove Write Protection 00:14:01 : ====================================================== 00:14:01 : --> DO NOT PERFORM THIS ON A NON SAMSUNG BRAND EMMC 00:14:01 : --> Make Sure you BACKUP eMMC DUMP Just In Case... 00:14:01 : ====================================================== 00:14:01 : 00:14:13 : Permanent Write Protection Removed! 00:14:13 : Perform USB Firmware Update if Needed... 00:14:13 : 00:14:32 : ====================================================== 00:14:32 : ====================================================== 00:14:32 : eMMC Test Point Connection Module 00:14:32 : ====================================================== 00:14:32 : ====================================================== 00:14:32 : 00:14:32 : 1. Make Sure CLK Test Point is already Soldered 00:14:32 : 2. Make Sure CMD Test Point is already Soldered 00:14:32 : 00:14:32 : 00:14:32 : Interface Reset OK! 00:14:32 : eMMC Access Type: SECTOR MODE 00:14:32 : eMMC Supported Voltage Range: 00:14:32 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 00:14:32 : 00:14:32 : CID : 1501004D414732474107201FA5A58F1F 00:14:32 : CSD : D02701320F5903FFF6DBFFFF8A404007 00:14:32 : 00:14:32 : eMMC Boot Information 00:14:32 : Revision 1.5 (for MMC v4.41) 00:14:32 : BOOT PARTITION : BOOT PARTITION 1 00:14:32 : PARTITION ACCESS : R/W USER PARTITION 00:14:32 : PERM_BOOT_CFG_PROT : DISABLED 00:14:32 : PWR_BOOT_CFG_PROT : DISABLED 00:14:32 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 00:14:32 : RESET BUS WIDTH : ENABLED 00:14:32 : eMMC FirmW UPDATE : DISABLED 00:14:32 : EMMC CACHE SIZE : 0 KB 00:14:32 : SUPER PAGE SIZE : 3584 KB 00:14:32 : HC ERASE GROUP SIZE: 512 KB 00:14:32 : USER AREA SIZE : 15758000128 BYTES 00:14:32 : BOOT PARTITION SIZE: 2048 KB 00:14:32 : RPMB PARTITION SIZE: 128 KB 00:14:32 : 00:14:32 : 00:14:32 : eMMC Device Information 00:14:32 : Manufacturer ID: SAMSUNG 00:14:32 : Device Type : Embedded BGA 00:14:32 : Application ID : 00 00:14:32 : Product Name : MAG2GA 00:14:32 : Product Rev : 0.7 00:14:32 : Product SN : 201FA5A5 00:14:32 : Manufactured : January 2012 00:14:32 : 00:14:32 : Card Specific Data 00:14:32 : CSD_STRUCTURE : Extended 00:14:32 : SPEC_VERS : Version 4.1/4.2/4.3 00:14:32 : TAAC : 13 ns 00:14:32 : TRAN_SPEED : 4000000 KHz 00:14:32 : READ_BL_LEN : 512 Bytes 00:14:32 : C_SIZE : HIGH CAPACITY 00:14:32 : WP_GRP_ENABLE : YES 00:14:32 : WRITE_BL_LEN : 512 Bytes 00:14:32 : CONTENT_PROT_APP : NO 00:14:32 : PERM_WRITE_PROTECT: NO 00:14:32 : TMP_WRITE_PROTECT : NO 00:14:32 : 00:14:32 : Extended CSD Saved: 00:14:32 : 1501004D414732474107201FA5A58F1F.ext_csd 00:14:32 : Backup Directory: 00:14:32 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 00:14:32 : 00:14:47 : ====================================================== 00:14:47 : ====================================================== 00:14:47 : eMMC Test Point Connection Module 00:14:47 : ====================================================== 00:14:47 : ====================================================== 00:14:47 : 00:14:47 : 1. Make Sure CLK Test Point is already Soldered 00:14:47 : 2. Make Sure CMD Test Point is already Soldered 00:14:47 : 00:14:47 : 00:14:47 : Interface Reset OK! 00:14:47 : eMMC Access Type: SECTOR MODE 00:14:47 : eMMC Supported Voltage Range: 00:14:47 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 00:14:47 : 00:14:47 : CID : 1501004D414732474107201FA5A58F1F 00:14:47 : CSD : D02701320F5903FFF6DBFFFF8A404007 00:14:47 : 00:14:47 : eMMC Boot Information 00:14:47 : Revision 1.5 (for MMC v4.41) 00:14:47 : BOOT PARTITION : BOOT PARTITION 1 00:14:47 : PARTITION ACCESS : R/W USER PARTITION 00:14:47 : PERM_BOOT_CFG_PROT : DISABLED 00:14:47 : PWR_BOOT_CFG_PROT : DISABLED 00:14:47 : BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED 00:14:47 : RESET BUS WIDTH : ENABLED 00:14:47 : eMMC FirmW UPDATE : DISABLED 00:14:47 : EMMC CACHE SIZE : 0 KB 00:14:47 : SUPER PAGE SIZE : 3584 KB 00:14:47 : HC ERASE GROUP SIZE: 512 KB 00:14:47 : USER AREA SIZE : 15758000128 BYTES 00:14:47 : BOOT PARTITION SIZE: 2048 KB 00:14:47 : RPMB PARTITION SIZE: 128 KB 00:14:47 : 00:14:47 : 00:14:47 : eMMC Device Information 00:14:47 : Manufacturer ID: SAMSUNG 00:14:47 : Device Type : Embedded BGA 00:14:47 : Application ID : 00 00:14:47 : Product Name : MAG2GA 00:14:47 : Product Rev : 0.7 00:14:47 : Product SN : 201FA5A5 00:14:47 : Manufactured : January 2012 00:14:47 : 00:14:47 : Card Specific Data 00:14:47 : CSD_STRUCTURE : Extended 00:14:47 : SPEC_VERS : Version 4.1/4.2/4.3 00:14:47 : TAAC : 13 ns 00:14:47 : TRAN_SPEED : 4000000 KHz 00:14:47 : READ_BL_LEN : 512 Bytes 00:14:47 : C_SIZE : HIGH CAPACITY 00:14:47 : WP_GRP_ENABLE : YES 00:14:47 : WRITE_BL_LEN : 512 Bytes 00:14:47 : CONTENT_PROT_APP : NO 00:14:47 : PERM_WRITE_PROTECT: NO 00:14:47 : TMP_WRITE_PROTECT : NO 00:14:47 : 00:14:47 : Extended CSD Saved: 00:14:47 : 1501004D414732474107201FA5A58F1F.ext_csd 00:14:47 : Backup Directory: 00:14:47 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 00:14:47 : |
11-15-2017, 04:49 | #2 (permalink) | |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | Quote:
11-15-2017, 07:02 | #3 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | supporter need help, now unit is dead, cant go to download mode, i did samsung emmc firmware update+format wrote boot 1,boot 2, user data, ext_csd which followed and downloaded from this post http://forum.gsmhosting.com/vbb/f609...n8000-1983997/ |
11-15-2017, 11:32 | #4 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | i manage to bring back alive .. but problem is when flashing with odin always failed and logs shows there is no pit partition.. i tried different pit file but always failed.. no one here is giving advise . atf support section is a ghost town though.. |
11-18-2017, 00:21 | #10 (permalink) | |
Freak Poster Join Date: Feb 2010
Member: 1247453 Status: Offline Thanks Meter: 13 | Quote:
Enviado desde mi HTC One_M8 mediante Tapatalk | |
