03-15-2017, 11:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | n82 rm-313 help for error flash ATF Box FBUS Flash Started... Number of Image Files: 3 Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ WARNING: Simlock Backup Failed If this is a Dead Phone, just click YES to Continue with the Flash Procedure... Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed Failed to complete RPL backup.. Processing Image File : C:\Users\hamid20\Desktop\35.0.002\RM-313_35.0.002_PR.C0R CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 51000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 471 Entry Point : 0x026E Page Format : 128K Maximum Page Size : 0x00030000 Changing MODE : FLASH Booting Phone via FBUS... BootFlashModeDCT5Ex Failed Operations Failed.... |
The Following User Says Thank You to mahi20015 For This Useful Post: |
