11-23-2013, 07:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | n9 Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending PRIMARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending SECONDARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Booting/Flashing Failed... Please Try Again... fhone is hang on logo when i flesh say that |
