05-04-2013, 09:33 | #6 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | on which file? 1fl61 Harmattan 40.2012.13-7.mea Emmc Mea.bin 2 fl61 Harmattan 40.2012.21-3 Pr Legacy 006-oem1-958 Arm.bin File Size : 1003.5 Mb |
05-04-2013, 09:44 | #7 (permalink) | |
No Life Poster Join Date: Oct 2012 Location: india
Member: 1825795 Status: Offline Sonork: 100.1621021:98 Thanks Meter: 183 | hi Quote:
http://mrcrab.net/nokia/Nokia_N9.htm...n=40.2012.21.3 | |
05-04-2013, 13:07 | #8 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Number of Image Files: 1 (Mass Memory File Detected) Processing Image File : 49C986EE_DFL61_HARMATTAN_40.2012.13-7.INDIA_EMMC_INDIA.bin CMT Type : MAEMO/MEEGO ================================================== ==== ================================================== ==== MAEMO / MEEGO BB5 USB Flashing ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port Communication Link Established! Reading Product Info... Product Code : RM-696 Hardware Revision : 1603 Software Release : DFL61_HARMATTAN_40.2012.21-3_PR_006 Software Platform : MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F 49C986EE_DFL61_HARMATTAN_40.2012.13-7.INDIA_EMMC_INDIA.bin C:\Documents and Settings\shani\My Documents\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Booting/Flashing Failed... Please Try Again... |
05-04-2013, 13:07 | #9 (permalink) |
05-04-2013, 13:42 | #10 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | @Shani3 You need to select BOTH files - MCU and eMMC - you can't flash only eMMC. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-04-2013, 15:07 | #11 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Number of Image Files: 2 (Mass Memory File Detected) Processing Image File : A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO Processing Image File : 49C986EE_DFL61_HARMATTAN_40.2012.13-7.INDIA_EMMC_INDIA.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\rm-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin -F 49C986EE_DFL61_HARMATTAN_40.2012.13-7.INDIA_EMMC_INDIA.bin C:\Program Files\Nokia\Phoenix\Products\rm-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 19:07:09 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Booting/Flashing Failed... Please Try Again... |
05-04-2013, 16:22 | #12 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | You are using old version files.... Use higher version. ================================================== ==== Variant Details : N9 RM-696 Country Variant United Arab Emirates AE CLI8 Black 16G / 64G Software Version : 40.2012.21.3 Product Type : RM-696 Product Code : 059L6B8 Variant Version : 010 ================================================== ==== |
05-05-2013, 09:04 | #13 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | ..::Angel::..@ thanks To all my problem is solve. i am so happy Number of Image Files: 2 (Mass Memory File Detected) Processing Image File : E9A9F33B_DFL61_HARMATTAN_40.2012.21-3.SSAEUCITIES.10_EMMC_SSAEUCITIES.bin CMT Type : MAEMO/MEEGO Processing Image File : E33E1B19_DFL61_HARMATTAN_40.2012.21-3.335.1_PR_LEGACY_335_ARM_RM-696_PRD_signed.bin CMT Type : MAEMO/MEEGO ================================================== ==== ================================================== ==== MAEMO / MEEGO BB5 USB Flashing ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port Communication Link Established! Reading Product Info... Product Code : RM-696 Hardware Revision : 1603 Software Release : DFL61_HARMATTAN_40.2012.21-3_PR_006 Software Platform : MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F E9A9F33B_DFL61_HARMATTAN_40.2012.21-3.SSAEUCITIES.10_EMMC_SSAEUCITIES.bin C:\Program Files\Nokia\Phoenix\Products\rm-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F E9A9F33B_DFL61_HARMATTAN_40.2012.21-3.SSAEUCITIES.10_EMMC_SSAEUCITIES.bin -F E33E1B19_DFL61_HARMATTAN_40.2012.21-3.335.1_PR_LEGACY_335_ARM_RM-696_PRD_signed.bin C:\Program Files\Nokia\Phoenix\Products\rm-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending PRIMARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending SECONDARY-BOOT: SUCCESSFUL! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated time to Finish Erasing: 12:52:17 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs Processing Image: mmc ========================================= All Images were Succssfully Uploaded! Software Update Done []: Found 1 active devices. [Nokia N900 USB Phonet]: Opening Connection [Nokia N900 USB Phonet]: Port opened OK! Rebooting Phone... Total Flashing Time (Erase + Flashing) : 00:21:56 (Booting time is NOT Included) Phone is not Connected OR it is not in the Required Mode... Reboot the Phone and Enable "PC Suite" Mode Life timer data is not yet used... Life timer: ----:-- ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.50 Software Version : v9.80 AdvanceBox SN : 8403069EA7044CF8E773F306 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED ================================================ Basic Phone Information ================================================ Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 92_11w51_3 19-04-12 RM-696 (c) Nokia IMEI Plain : 357923043547480 IMEI Spare : A357923043547480 IMEI SV : 33579230435474840F Phone Model: Nokia NoRM6 Category : Nokia Reference Mobile Phone Type : RM-696 ================================================ Extended Phone Information ================================================ Product Serial Number: CQI932767 Product Code : 059J217 Module Code : 0204965 Basic Production Code: 059G8V7 BT MCM Version : 6.15 MCU SW Version : V 92_11w51_3 19-04-12 RM-696 (c) Nokia HW Version : 1603 RFIC Version : |Alli_4.b.1 DSP Version : 92_11w51_3 LCD Version : fe.91.96 Camera : 0b:0125:02 APE BT Version : 00060000060d0020 Content Pack Version : DFL61_HARMATTAN_40.2012.21-3.SSAEUCITIES.10 AHNE Version : 21 Bootcode Version : 2.3.6 APE SW Core Version : 40.2012.21.3.335.1 V 1.3.2 RM-696 (c) NOKIA. APE Test Version : V 1.3.2 RETU Version : 11 TAHVO Version : 00 APE HW Version : 1603 Wireless LAN ID : 9C:CA9:A6C:FB Bluetooth ID : 9C:CA9:A6:40:BB ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000003 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST DCC ID : NOT USED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... Changing Phone Mode... (Wait for 10 seconds) Successfully set to : Normal |
05-05-2013, 10:26 | #14 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 345808 Status: Offline Thanks Meter: 21 | Number of Image Files: 1 Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin C:\Documents and Settings\Administrator\Desktop\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Sending PRIMARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending SECONDARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs ERROR: MEEGO Device Flashing Failed! Booting/Flashing Failed... Please Try Again... |
