10-30-2012, 11:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: West Africa Ghana Age: 15
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | N9 Error Occured PROBLEM <<< SOLVED >>> Error Occured Can't connect to network.contact nokia care point Please how do i solve this problem in advance Thank you |
10-30-2012, 14:09 | #3 (permalink) |
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM (mcu) RM696_059J1Z5_40.2012.21.3_001.dcp RM696_059J1Z5_40.2012.21.3_001.vpl RM696_059J1Z5_40.2012.21.3_001_signature simlock_maemo__deB_allowed2_3gstandard_bb5_multi_a sic0 simlock_maemo__deB_allowed2_3gstandard_bb5_multi_a sic1 I know first file is mcu,which of the other files is eMMC+Factory Set.. If i select phoniex ini on software only first file comes in mcu. Selected VPL File: RM696_059J1Z5_40.2012.21.3_001.vpl ================================================== ==== Variant Details : RM-696 NDT 16GB BLACK Software Version : 40.2012.21.3 Product Type : RM-696 Product Code : 059J1Z5 Variant Version : 001 thank you |
10-30-2012, 14:17 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | MCU - DFL61_HARMATTAN_40.2012.21-3.335.1_PR_LEGACY_335_ARM_RM-696_PRD_signed.bin eMMC - DFL61_HARMATTAN_40.2012.21-3.SSAEUCITIES.10_EMMC_SSAEUCITIES.bin Factory Set - the option to tick in ATF Software after you select N9 Model. BR |
10-30-2012, 15:53 | #7 (permalink) |
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | how??? because any file i download and after selecting ini i get only DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM inside mcu in software Can you please guide me on how to download the file? |
10-30-2012, 15:56 | #8 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Variant Details : N9 RM-696 Country Variant United Arab Emirates AE CLI8 Black 16G Software Version : 40.2012.21.3 Product Type : RM-696 Product Code : 059L6B8 Variant Version : 010 BR |
10-30-2012, 16:15 | #9 (permalink) |
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | my atf have problem now. if i connect box software open it can't detect box.if you check at device manager you see usb serial converter A usb serial converter B how do i fix this problem? |
10-30-2012, 16:22 | #10 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
Both Soft have a Virus and Non Compatible ftdi.sys and dll.- Not Write with Mprog, delete all Ftd/* restart, run ccleaner for clean registry and install ftd from ATF Path again. I solved This problem in Windows XP and Windows 7 64Bit br polaco | |
10-30-2012, 16:29 | #11 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
10-30-2012, 22:37 | #13 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | I solved This problem only with a FTD Files and windows xp and 7, and using Other USB Port.- That ShortCut is Crazy,dangeroius and not serius..... If Work...is positive..... , but i dont undesrtand because this problem was in ATF Plastic Box, Non in ATF Big Chrome..... I see, iam a Lucky ATF User, The Box not Work fine for many user....but Mi Box, Work Perfect From the First day, i not use Other Tools For Nokeya, only ATF.. Best regards Polaco |
