01-09-2015, 13:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Nowshera
Member: 2217500 Status: Offline Sonork: 100.1597179 Thanks Meter: 326 | n9 flashing error Processing Image File : DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3.468.1_PR_LEGACY_468_ARM_RM-696_PRD_signed.bin H:\products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 17:50:15 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... |
