10-31-2012, 07:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | n9 flashing failed (Mass Memory File Detected) Processing Image File : DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO Processing Image File : DFL61_HARMATTAN_30.2012.07-1.NOMAPS_EMMC_NOMAPS.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_30.2012.07-1_PR_LEGACY_001-OEM1-958_ARM.bin -F DFL61_HARMATTAN_30.2012.07-1.NOMAPS_EMMC_NOMAPS.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 08:07:58 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Booting/Flashing Failed... Please Try Again... |
10-31-2012, 10:30 | #2 (permalink) | ||
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | http://forum.gsmhosting.com/vbb/8522406-post7.html Quote:
Br - srinibas | ||
The Following 2 Users Say Thank You to srinibas For This Useful Post: |
11-03-2012, 12:46 | #3 (permalink) | |
Member: 430612 Status: Offline Thanks Meter: 301 | Quote: Number of Image Files: 2 (Mass Memory File Detected) Processing Image File : DFL61_HARMATTAN_30.2012.07-1.523.2_PR_LEGACY_523_ARM_RM-696_PRD_signed.bin CMT Type : MAEMO/MEEGO Processing Image File : DFL61_HARMATTAN_30.2012.07-1.SEAP_EMMC_SEAP.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_30.2012.07-1.523.2_PR_LEGACY_523_ARM_RM-696_PRD_signed.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_30.2012.07-1.523.2_PR_LEGACY_523_ARM_RM-696_PRD_signed.bin -F DFL61_HARMATTAN_30.2012.07-1.SEAP_EMMC_SEAP.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 13:42:22 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Booting/Flashing Failed... Please Try Again... i use latetest verion still the same | |
