12-06-2012, 08:05 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Ãfgĥäñîštâй
Member: 1844204 Status: Offline Sonork: 100.1111172 Thanks Meter: 337 | N9 successfully flashed with Atf 9.20 Number of Image Files: 2 (Mass Memory File Detected) Processing Image File : DFL61_HARMATTAN_22.2011.44-2_PR_LEGACY_006-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO Processing Image File : DFL61_HARMATTAN_22.2011.44-2.MEA_EMMC_MEA.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_22.2011.44-2_PR_LEGACY_006-OEM1-958_ARM.bin C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_22.2011.44-2_PR_LEGACY_006-OEM1-958_ARM.bin -F DFL61_HARMATTAN_22.2011.44-2.MEA_EMMC_MEA.bin C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending PRIMARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending SECONDARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs Processing Image: mmc ========================================= All Images were Succssfully Uploaded! Software Update Done []: Found 1 active devices. [Nokia N900 USB Phonet]: Opening Connection [Nokia N900 USB Phonet]: Port opened OK! Rebooting Phone... Total Flashing Time (Erase + Flashing) : 00:05:45 (Booting time is NOT Included) |
12-06-2012, 09:49 | #4 (permalink) |
Member: 1844204 Status: Offline Sonork: 100.1111172 Thanks Meter: 337 | Yes bro your right,but most users have problem with flashing read B4 flash:http://forum.gsmhosting.com/vbb/f609...nside-1494320/ |
