05-09-2014, 17:32 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | N9 Unable to read SP Data..???? I Have Before Flash Full PM Backup I Write But See Many Field Write Failed ATF Team Please Help Me? Here Is Before Flash PM & Certificate Backup. https://forum.gsmhosting.com/vbb/****************************/?k5d4gnk5lbbr581 Code: Field : 1 Sub : 0 Byte(s): 12 - [Requires SX4] Field : 1 Sub : 1 Byte(s): 96 - [Requires SX4] Field : 1 Sub : 2 Byte(s): 112 - [Requires SX4] Field : 1 Sub : 4 Byte(s): 12 - [Requires SX4] Field : 1 Sub : 6 Byte(s): 112 - [Requires SX4] Field : 1 Sub : 7 Byte(s): 452 - [Requires SX4] Field : 1 Sub : 8 Byte(s): 12 - [Requires SX4] Field : 1 Sub : 13 Byte(s): 112 - [Requires SX4] Field : 1 Sub : 15 Byte(s): 32 - [Requires SX4] Field : 1 Sub : 16 Byte(s): 32 - [Requires SX4] Field : 1 Sub : 17 Byte(s): 32 - [Requires SX4] Field : 1 Sub : 18 Byte(s): 32 - [Requires SX4] Field : 1 Sub : 19 Byte(s): 32 - [Requires SX4] Field : 1 Sub : 22 Byte(s): 24 - [Requires SX4] Field : 1 Sub : 26 Byte(s): 12 - [Requires SX4] Field : 1 Sub : 27 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 28 Byte(s): 112 - [Requires SX4] Field : 1 Sub : 29 Byte(s): 12 - [Requires SX4] Field : 1 Sub : 30 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 31 Byte(s): 24 - [Requires SX4] Field : 1 Sub : 32 Byte(s): 216 - [Requires SX4] Field : 1 Sub : 33 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 35 Byte(s): 24 - [Requires SX4] Field : 1 Sub : 36 Byte(s): 24 - [Requires SX4] Field : 1 Sub : 38 Byte(s): 216 - [Requires SX4] Field : 1 Sub : 39 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 40 Byte(s): 24 - [Requires SX4] Field : 1 Sub : 41 Byte(s): 216 - [Requires SX4] Field : 1 Sub : 43 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 44 Byte(s): 216 - [Requires SX4] Field : 1 Sub : 45 Byte(s): 216 - [Requires SX4] Field : 2 Sub : 0 Byte(s): 2240 - Failed Field : 8 Sub : 0 Byte(s): 4 - Failed Field : 8 Sub : 1 Byte(s): 16 - Failed Field : 8 Sub : 2 Byte(s): 16 - Failed Field : 8 Sub : 3 Byte(s): 128 - Failed Field : 8 Sub : 4 Byte(s): 128 - Failed Field : 8 Sub : 8 Byte(s): 8 - Failed Field : 11 Sub : 0 Byte(s): 4 - Failed Field : 11 Sub : 1 Byte(s): 4 - Failed Field : 11 Sub : 2 Byte(s): 4 - Failed Field : 11 Sub : 3 Byte(s): 4 - Failed Field : 11 Sub : 4 Byte(s): 1052 - Failed Field : 12 Sub : 0 Byte(s): 8 - Failed Field : 26 Sub : 0 Byte(s): 16 - Failed Field : 26 Sub : 1 Byte(s): 68 - Failed Field : 31 Sub : 4 Byte(s): 12 - Failed Field : 44 Sub : 0 Byte(s): 4 - Failed Field : 50 Sub : 0 Byte(s): 4 - Failed Field : 96 Sub : 0 Byte(s): 4 - Failed Field : 117 Sub : 0 Byte(s): 4 - Failed Field : 117 Sub : 1 Byte(s): 4 - Failed Field : 117 Sub : 2 Byte(s): 8 - Failed Field : 117 Sub : 3 Byte(s): 4 - Failed Field : 117 Sub : 5 Byte(s): 12 - Failed Field : 117 Sub : 6 Byte(s): 8 - Failed Field : 117 Sub : 8 Byte(s): 44 - Failed Field : 117 Sub : 13 Byte(s): 4 - Failed Field : 117 Sub : 14 Byte(s): 4 - Failed Field : 117 Sub : 16 Byte(s): 40 - Failed Field : 120 Sub : 0 Byte(s): 944 - Failed Field : 120 Sub : 1 Byte(s): 160 - Failed Field : 120 Sub : 2 Byte(s): 132 - Failed Field : 120 Sub : 3 Byte(s): 112 - Failed Field : 193 Sub : 2 Byte(s): 8 - Failed Field : 193 Sub : 3 Byte(s): 32 - Failed Field : 193 Sub : 4 Byte(s): 32 - Failed Field : 193 Sub : 9 Byte(s): 64 - Failed Field : 217 Sub : 0 Byte(s): 32 - Failed Field : 239 Sub : 0 Byte(s): 4 - Failed Field : 239 Sub : 1 Byte(s): 3116 - Failed Field : 239 Sub : 2 Byte(s): 3116 - Failed Field : 239 Sub : 3 Byte(s): 3116 - Failed Field : 239 Sub : 4 Byte(s): 3116 - Failed Field : 239 Sub : 5 Byte(s): 3116 - Failed Field : 308 Sub : 1 Super Dongle Key Found Field : 308 Sub : 1 Write Super Dongle Key - OK Field : 322 Sub : 0 Byte(s): 4 - Failed Field : 334 Sub : 0 Byte(s): 4 - Failed Field : 360 Sub : 0 Byte(s): 4 - Failed Field : 360 Sub : 1 Byte(s): 4 - Failed Field : 360 Sub : 2 Byte(s): 4 - Failed Field : 369 Sub : 0 Byte(s): 40 - Failed Field : 388 Sub : 0 Byte(s): 4 - Failed PM Upload Done!... WBR. Arsalan gsm2000. |
05-09-2014, 17:53 | #2 (permalink) |
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Write Certificate Backup Field 120 Failed So??? Code: Field : 120 Sub : 0 Byte(s): 944 - Failed Field : 120 Sub : 1 Byte(s): 160 - Failed Field : 120 Sub : 2 Byte(s): 132 - Failed Field : 120 Sub : 3 Byte(s): 112 - Failed Field : 308 Sub : 1 Super Dongle Key Found Field : 308 Sub : 1 Write Super Dongle Key - OK PM Upload Done!... WBR. Arsalan gsm2000. |
