01-20-2011, 04:35 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: where love is Age: 33
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | when i select bb5 old loaders i am able to scan the phone MCU: V 08.54 25-10-10 RM-540 (c) Nokia IMEI: 3526xxxxxxxxxx Model : Nokia X3-00 Product Serial Number: KRD413532 Product Code : 0584014 Module Code : 0204201 Basic Production Code: 0578316 Default SN Type : 0 MCU SW Version : V 08.54 25-10-10 RM-540 (c) Nokia R BT MCM Version : 1673-46038 PPM Version : V 08.54 25-10-10 RM-540 (c) Nokia HW Version : 2000 RFIC Version : 0831 DSP Version : ICPR91_10w11_2 LCD Version : SEIKO Content Pack Version : Content: r_0580948 V 08.54 02-11-10 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 1251985 PHONE_MODE : LOCAL MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301035420 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR0301035420 Write the correct DCC to Fix the Problem when i press flash i get this error ATF Software Version v6.50 ATF Box FBUS Flash Started... Number of Image Files: 3 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-540\rm540__08.54.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 136 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed Operations Failed.... when i select new bb5 loaders i get this error ATF Software Version v6.50 ATF Box FBUS Flash Started... Number of Image Files: 3 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-540\rm540__08.54.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 136 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 Changing MODE : FLASH VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed Operations Failed.... Forcing Test Mode via BUSCHECK... VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... VBATT OFF... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 11 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 67042708 (0x94) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02034100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0D200204 ID DWORD 1 : 38770E49 ID DWORD 2 : EA0110D7 ID DWORD 3 : 95B0D0DD ID DWORD 4 : 29F757DD 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 Checksum E2 SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 ERROR: Phone did not respond... ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT ERROR : PHONE READ INFO FAILED Use "BUSCHECK" Button to Force the Phone into Local Mode... Then "SCANPHONE" after. For N95, N95-8GB and E90 Phones, you need a Test Mode Adapter to provide some Extra Power so that the Phone will go into Local Mode... |
01-20-2011, 08:52 | #10 (permalink) |
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | mobile problem was hang on nokia logo , i flash the mobile via usb flash ok mobile now on but no network . i need to flash and write pm so that my problem will solve . but mobile not booting anybody give me working solution thanks in advance |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-21-1999 11:05 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
fbus-mbus | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-05-1999 13:46 |
