07-07-2014, 13:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | N9005 4.4.2 Sd Card Ok, Phone in "Odin Mode" one Time, now Dead!!! Have insert this in the Samsung and after 2 attempt device is how in photo, but not having ready Multiflash File + mx-pit have disconnect battery for download it, but now with Same Card, Same procedure N9005 wont more entered in Odin Mode. Here Photo when have done Boot card, i see Restries, what's it? And Now when N9005 is in Odin Mode, (not want more enter in this mode, What's the problem?: I'm not think eMMc is damaged becouse how can see has started in Odin Mode 2 times, now not want more enter in this mode, Why?, reply please, Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
07-07-2014, 18:08 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts So when it entered ODIN MODE, you did not flash anything to the phone? Try to re-write your SDC File to your SD Card just to make sure nothing is corrupted. Also check if phone can already enter ODIN Mode without the SD CARD Inserted. |
07-07-2014, 18:26 | #4 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | No, Full Firmware with Ap, Cp itc...was dowloading, and for error battery disconnected. I've rewrite sdc card, charged battery and device restarted other time in Odin Mode, also this time has started W/O sdc card inside but Full Flash was not ready fault of mx-pit, so other time power off. From this time holding power button only vibro for two time but not power on. Can be Battery problems? i charge this with external adapter BR |
07-07-2014, 18:30 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts I am not a Samsung Expert... but I would suggest you use a REGULATED external power supply and a DOWNLOAD MODE JIG. Just need to connect (+) and (-) to external power supply instead of using battery. From your story, it is possible that it was LOW BATTERY problem... |
07-20-2014, 11:19 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Successful Repaired, only have rewrite card and put in the N9005 with FULL CHARGE battery and how the Video all ok, Odin Mode and Flashed with 4 files + Pit 32GB BR allumts |
